C5 Mk 1 2004 2.0 HDI problem
Graham55
Re: C5 Mk 1 2004 2.0 HDI problem
Unread post by Graham55 »
Hang on a sec, when I can't accelerate, the car still drives, it's just that the revs and speed will not increase. If the brake switch was cutting off the fuel supply, surely the engine would die?
x 5613
This is true.
Check for the brake lights coming on fairly randomly and intermittently but it probably isn't that.
Sounding more like a boost problem.
Any chance you could contact one of our Lexia owners and have a diagnostic session. A live data test may pick up on what is happening and why.
Lighty
x 35
Unread post by Lighty »
The switch is under the glovebox, fitted to the brake crossover bar.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Graham55
myglaren wrote:This is true.
Looking at the list, adamtemp64 is not too far away from me, I will pm him.
Graham55
Update on the above.
The short pipe/hose is the fuel pump drain hose - thanks for that.
On the advice of a friend, a triple dose of Millers fuel additive was added to the tank. That was 10 days ago. Not had the problem for a week now.
Adamtemp64 - fellow member has a Lexia, went through a series of tests/diagnostics today - all passed no faults. Thank you Adam.
So whatever it was appears to have gone away - has the Millers done the trick ?
Thanks for all the advice.
Graham
