c5 tps
oneday
c5 tps
Unread post by oneday »
hi only had this c5 2003 2,0 hdi vtr fot two weeks but after driveing a 2001 xsara for a few years it seems to have a lot of movement on the peddle before it responds. can anyone tell me where it is possitioned and is there anyway to adjust it or is it a case of fit a new one thanks in advace for any help
306 1.4 LX MERIDIAN
x 1240
Re: c5 tps
Unread post by Peter.N. »
If its the accelerator pedal you are referring to, there is a slight delay in response because its an electronically controlled engine, whether you can adjust the position I'm afraid I don't know but I am sure someone who does will be along soon.
oneday
Re: c5 tps
hi its not the delay its the movement in the peddle before anything happens 1 to 2 inches of peddle movement before anything will happen. i know on the xsara its on the bulkhead and you just remove the slack from the cable. the problem is i cant find this one. thanks for your help
306 1.4 LX MERIDIAN
oneday
Re: c5 tps
its ok ive found where it hidden
306 1.4 LX MERIDIAN
mooseshaver
Re: c5 tps
Unread post by mooseshaver »
I think the 2.2 mk1 was under the airbox and often needed slack taken out. 2.0 might be the same.
A garage did mine as I got scared trying to take out the airbox. Took them 5 mins I think
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
mooseshaver
Re: c5 tps
Too slow typing!
Gone cars.
oneday
Re: c5 tps
thanks just been in engine bay noticed a cable under the thr fuse box behind the air box. job for the weekend i think. thanks anyway
306 1.4 LX MERIDIAN
x 5674
Re: c5 tps
mooseshaver wrote:I think the 2.2 mk1 was under the airbox and often needed slack taken out. 2.0 might be the same.
Just had mine adjusted and the difference is amazing.
oneday
Re: c5 tps
anything less than 2inch of useless free play on the throttle would be great
306 1.4 LX MERIDIAN
x 5674
Re: c5 tps
There shoult only be 1/16" ideally.
I didn't do my own, it was done along with a pile of other things for the MOT.
oneday
Re: c5 tps
i will work to that wasn*t sure how much plat it should be just now i have to much thanks
306 1.4 LX MERIDIAN
oneday
Re: c5 tps
just took the slack out of the throotle cable. what a differance lifted the peddle about an inch. now when i put my foot down it realy goes
306 1.4 LX MERIDIAN
