Pleiades
A list of garages and suppliers that have given proven good service to members. All submissions to this forum must be approved by either an Admin or a Moderator before inclusion.
x 5683
Pleiades
Pleiades
Unit 12A Brookside Industrial Estate
Sawtry
PE28 5SB
Email:
pleiades.sawtry@gmail.com
Tel: (UK) 01487 831239
Very easy to find, just off the A1M between St. Neots and Peterborough.
Twickersdude
Hello & thank you - Pleiades
Unread post by Twickersdude »
Hello,
I found this forum whilst becoming very annoyed with Citroen who have now delisted the spare part that I needed for my 1999 Xantia 2.0 HDi. The hydraulic steering pipe had failed and Citroen were happy enough to accept an order for a replacement pipe assembly ( at close to £200.00 ) . After 3 weeks Citroen explained that the part was no longer available.
Following this forums recommendations I sent the failed part to Pleiades in Sawtry who repaired it for £65.00 inc. postage & returned it within 24 hours. I can't recommend them enough and am sure that I'll be using them again to help keep the Xantia running despite the best efforts of Citroen to send it to an early grave !!!!!!
Thank you to the forum & also to Martin Dunn at Pleiades.
Michael.
x 5683
Re: Hello & thank you - Pleiades
Thanks for the accolade Michael, always good to hear of good service even though Pleiades are renowned for the excellence of their operation.
Post moved to a more appropriate location.
ken.chapman
Pleiades, Sawtry PE28 5SB
Unread post by ken.chapman »
Hi all,
Had a problem with my C5 X7 and stiff suspension and bouncy - took it to Pleiades and was most impressed, I'd be happy to recommend anytime.
Ken Chapman
C5 2008 onwards (Phase 2 X7) Excusive Auto Saloon
Last 8 on the VIN: 54028743
Aircraft Engineer and Global Quality Manager who doesn't like working on cars!
x 8444
Re: Pleiades
Thanks Ken, always good to hear a recommended place is still good :-D
wurlycorner
x 271
Re: Pleiades
Unread post by wurlycorner »
Out of interest, what did they do and how much did it cost?
Iain
CX DTR T2 Safari (silver)
ken.chapman
Re: Pleiades
4 new spheres supplied and fitted, LDS fluid change and labour all for about £300 - quite good I thought and so much so, when I'm paid, I'll also have the rear centres done as well. Also told the cambelt kit including water pump and labour is only going to run to about £300 so I'll most likely have that done with them as well when it's due....
Ken Chapman
Edhertz
x 6
Re: Pleiades
Unread post by Edhertz »
I would like to add my hapenny's worth and say ‘thanks’ to the nice man at Pleiades, Sawtry, who spent some time on the phone helping me source a couple of seals (5280.K5) recently for my Xantia, Cheers Alan
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
Tudy
Re: Pleiades
Unread post by Tudy »
Good day everyone I want to ask if I can use the central hydraulic system fluid (CHF 11s) which carries the PSA S71 2710 specification in the BMP6 Actuator, it is very difficult to source for the CS speed tutela fluid or ravenol GHA-F liquid here in Nigeria
I conducted research from other manufacturers who use the same transmission concept as the dual logic that is made from the same marelli magnet, i.e. Suzuki.....which uses ecstar AMT fluid for Suzuki cars, but very expensive, it comes in a 550ml bottle
Any suggestions will be very grateful
Thank you
