Here's a tip for you if you're replacing the drop link,
use a blow lamp on the back side of the ball joint part of the drop link, this melts the plastic cup that the ball sits in and then you can pull the rod off the ball joint, this leaves just the metal ball in place. Use a pair of stilsons on the ball to hold it and you can then remove the nut easily either with a ratchet or windy gun.
I've used this method a few times, I find it easier than getting the grinder out and showering myself with sparks.
Cheers.
Xantia drop link nuts ?
uncle buck
- x 10
Re: Xantia drop link nuts ?
2001 Xsara II 1.4 LX
- x 695
Thanks Richard.RichardW wrote:Grinder, cutting discs, power supply, ramps, drive to work on, MIG, + tea supply at mine if you need it in the future
Somehow I seem to think I can tackle these things on my own with limited facilities, then get myself into trouble, but nearly always manage to scrape my way through to success! It amazes me sometimes just what I can manage to do when there is a deadline and I'm desperate to get the job finished as failure is not an option. After all I'm a computer/electronics geek not a mechanic.
- x 695
Good tip. Interesting thing is the old drop links had the plastic back you refer to (Citroen originals I think!) but the Lemforder replacements have a steel cup on the back of the top joint.uncle buck wrote:Here's a tip for you if you're replacing the drop link,
Cheers.
What I did on one of the top nuts that wouldn't let go was to use a ball joint splitter to clamp the back of the ball joint solidly to the tab on the strut, then use a small gas torch to heat the nut and managed to undo it with a socket that way! The other top one I had to hacksaw, but that only took about 15 minutes as it was just through the bolt thread as I had got the nut mostly undone before the centre hex stripped. The bottom one that I had to hacksaw was through the nut as well as I couldn't budge the nut, that one took about 2 hours.
At least the weather was beautiful and sunny throughout the job. I was so tired from 2 hours of hacksawing on top of all the other work I nearly fell asleep in the sun on the ground, luckily I didn't or I would have run out of time to finish the job!
uncle buck
- x 10
Even if it has a a metal cover on the back there will be plastic inside that will melt allowing the cup to be pulled from the ball.Mandrake wrote:Good tip. Interesting thing is the old drop links had the plastic back you refer to (Citroen originals I think!) but the Lemforder replacements have a steel cup on the back of the top joint.
Cheers.
Foggyoutcome
I just put I couple of cuts in the nut using the grinder and away it came with a spanner.
I've never done this job before but I replaced both front drop links in about half an hour.
uncle buck
- x 10
To stop future problems of nut removal cover the threads of the new drop link with a good coating of grease or wax oil, this will stop them rusting, so you can remove them easily when the time comes.
Cheers.
Cheers.
- x 3306
Hello all,
I had to do the drop links on my Xantia S2, and I thought it would be easy, as I had done this before without any problems on my previous S2. Boy was I WRONG!
! Both of them had a nut that was seized, and when they did move, they only got halfway down the stem before locking up (despite me wire brushing them and using WD40 before I started work!)
. Once I had got them that far there was no going back, but I was stuffed, as I do not have either an angle grinder or a blowtorch. I started to think the problem through, and came up with an idea that worked this time for me
. I was fortunate that I had space for it to work
Remove the gaiter from the relevant stem. Clamp a mole grip onto the gaiter mounting point on the stem (make sure it is tight). Now, with luck
you should be able to remove that pesky locknut.
I hope that this is of use.
