Let's hope this is NOT the beginning of dozens of potential faults I have...
The aircon on the C5.
How do I know it's working? Just the fact that the blower blows? Should there be noticeably cold air coming from the vents?
At the moment it's hard to tell. Even on 14 I can't honestly say it feels cool in there. Am I running the engine long enough? Any special tweak I might be missing?
As far as I can see, to turn on the a/c you press the auto button, and to turn it off, or at least the blower, press the fan button until the blowing reduces and seems to stop.
C5 aircon question - not sure if it is working or not
Napoleon
- x 4
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
hdi_man
Re: C5 aircon question
Maybe it needs re-gassed? You should definitely feel it cold, ice cold if you set it to low. Auto its on climate control but you can also just press the AC button
Lighty
- x 35
The MK111 C5 has a few common leak point with the A/C pipes, I have changed about 5 this year.
You should feel the chill from it in this weather as already said. Get it regassed with a dye, the technician will test for leaks at the time .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Napoleon
- x 4
Is re-gassing a sort of job my mobile mech-type guy can do? He does stuff for me such as fitting accessories, split charge relays and so on, and I remember his card saying something about aircon work.
I know I have to ask him, but just wondered if you chaps think that he might be a likely first port of call?
Tim
Tim
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
waynedance
- x 8
Re: C5 aircon question - not sure if it is working or not
Should be like sitting in a fridge, left my engine running with a/c on today for 5 mins and then got in the car and is was well chilled.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Napoleon
- x 4
In that case, something's not right.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
waynedance
- x 8
Air con either works or it don't, should here the compressor kicking in & out.
Water dripping on the floor & very cold or near frozen air con pipes in the engine bay is a good indication it's working.
Napoleon
- x 4
Have yet to venture near the engine bay, so, in Citroen terms, I don't know my arse from my elbow.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 1480
If you bought it at a garage, then you should take it back and get them to fix it - it is covered under sale of goods - whatever they may say about 'Warranty'
If you're not sure it's working, then it isn't - if it is working properly then the air coming out the vents will be too cold to hold your hand in front of for long. Note if the gas pressure is low, then it can cool a bit, so it will feel cool rather than cold.
SaabC5
A good test of how cold your air con is getting is to direct the air at the windscreen on the coldest setting, if its working correctly you will find a small ice patch will form at the bottom of the screen if you run it for 15-20 mins.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
addo
- Sara Watson's Stalker
- x 95
hdi_man
other thing that it could be is your external temperature sensor on the drivers wing mirror is faulty...I currently have this problem, car reads 3 degress when its actually 15. so when I put AC on low it won't actually come on as the climate control uses the outside air temp I believe
Napoleon
- x 4
Right, the car's going back when we get back from France.
I had an A/C man test it and the system showed a leak. There was no gas in the system, and a test with nitrogen showed a leak somewhere near, if not on, the condensor.
Rang garage just after findin this and they say take it back to them.
Grrr. Should have checked this when I saw the car, shouldn't I?
Then again, what about the 8,000,000 checks they say they carry out prior to sale? Didn't that include the a/c?
Right that's it, see you in a while.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 3566
I recently had my aircon condensor on my C5(X7) holed by a stone thrown up from the road so don't assume that the garage supplied you with duff aircon. My aircon was working fine one day and not working at all the next. When the garage tested my aircon system the Nitrogen was very obviously coming from a hole in the condensor. I think the condensors may be made of 2 sheets of Bacofoil stuck together so may be a bit fragile !!
Napoleon
- x 4
I've only done about 100 miles in the car. There was NO gas in the system whatsoever.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
