berlingo speedometer
shazaam
New User
Unread post by shazaam »
hi all i,ve not had my berlingo van long its a 2008 reg but i,ve noticed the mileage display pixels are playing up and getting very faint could i buy a used speedometer would it still show my mileage as its only done 56k with history, or would it show the donors mileage thanks
x 1044
Re: berlingo speedometer
Unread post by wheeler »
If the dash clocks you fit has a higher milage you will inherit the higher milage.
If the clocks you fit have a lower milage the 'new' clocks will change to your vans current milage.
spider
x 77
Unread post by spider »
As above really it will take the higher mileage, you'd have to change both the BSi and the clocks from the same donor to stand a chance of keeping the mileage, and then it might not work. Not 100% sure but if you just change the clocks as Wheeler has said it will go up, not down.
Andy.
