C5 suspension won't move
cachaciero
x 9
Re: C5 suspension won't move
Unread post by cachaciero »
Gibbo2286 wrote:I've had a few of these pumps apart, they suffer with corrosion inside the electric motor and either keep blowing the fuses or burn the motor coils rendering the pump useless. There's a thread on here somewhere where I posted some pictures,
Yep! that happened to me too, one brush wire had corroded right through and there were segments burned on the commutator, actually the brush wire may have fused due to high current caused by shorted winding, I had been putting in a bigger fuse each time it blew, maybe jhad reached the point where the brush wire was a better fuse than the fuse :-)
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Jerome3
Unread post by Jerome3 »
So do I need a new pump then?
x 2938
You may be able to find a good used one, there are plenty coming on to the market now, or your own may be repairable, the one I'm using had green copper corrosion eaten through about 5mm of the wire in the motor, I cut it out and soldered in some new wire and it's been fine now for over a year.
New pumps cost in the region of £500 so not a good idea on a cheapo car.
First thing to do of course is get it diagnosed properly.
Jerome3
Would there be any funny noises come from pump prior to failure?
cachaciero
x 9
Jerome3 wrote:Would there be any funny noises come from pump prior to failure?
Maybe maybe not, loss of a winding or two might make the motor sound a bit rough but you would probably have to have your ear close to it to hear.
As has been said there are pumps appearing on the S/H market, as far as I can see after about 2003 the motors are all the same might be that the valve block / ECU are the same as well, however don't worry about it too much, it is easy to remove the motor from a scrapper and fit it to your valve block / ECU.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Jerome3
Just noticed this morn a fair amount of fluid lying below her could they be related?
Jerome3
cachaciero
Would I have to bleed the system after fitting it
x 2938
It's self bleeding but you might have to raise the pressure in the reservoir to about 5 psi to get the self bleed started, sometimes it will go without but that's the recommended way. Cobble together an adapter for the lid with a bike valve and pump it up a bit, doesn't need much.
Jerome3
just removed my suspension pump unit should i have to match it with another same kind o pump does it have a part number? mines an 02 110 hdi sx
cachaciero
x 9
I think any pump you can find will do for an SX trim car, the important thing is age / mileage, less of either is good, the newer the pump the longer it will be before you have to do the job again :-). Would suggest stripping the motor of the "new" pump to check for corrosion / water ingress in the brush area also look for blackened commutator segments which would be an indication of a winding short. When putting it back together the use of silicon grease on the brush wires and connections to limit water damage is good also take care to ensure that the cover is well sealed against water ingress.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Jerome3
Got a second hand pump it came of a vtr model hope it suits have it fitted just need to no which fluid lhm or lds and us there a method to the bleeding I.e do I bore a hole in a cap fit a bike valve on it pump it to pressure turn car on and work suspension all help greatly appreciated
Jerome
x 5672
Definitely ONLY LDS - it does say on the reservoir!
There are bleed valves under the car, cachaciero has mentioned this in other threads, can't say where they are as my car isn't here right now.
Yes, to prime the pump you will need to pressurise the reservoir.
Jerome3
When I got the pump the ecu was attached so I just popped in complete unit hope this is ok,then I filled the reservoir i need to know wot to do now sort of a step by step thing if anybody could let me no it would be much appreciated I was also wondering if my car has a front height sensor I have replaced the rear with a a new one
Thanx again jerome
x 5672
Your car does have a front height sensor, it will be attached to the anti roll bar.
As for detailed instructions on commissioning the new pump, wait a bit for someone more knowledgeable to show up. Likely cachaciero or wheeler will be best informed on this matter.
x 2938
Apply a pressure of 0,5 bar in the LDS fluid reservoir (using a FACOM 920 tool) .
Start the engine .
Wait for the vehicle height to stabilise .
Put the vehicle in the "high" position .
Lower the vehicle to the low position .
Turn the steering from lock to lock in each direction .
Stop the engine .
Check the LDS fluid level .
