xantia hdi rear electric windows and sunroof not working
lurchy666
hello i just brought a xantia (110 hdi sx on t plate) with electric windows and sunroof, the problem i got is fuse 10 and 11 which supply the rear windows and sunroof are completly dead, does anybody know where these fuses are fed from as i have tested all the engine bay fuses and they are all ok, or could it be a broken cable somewhere
c5 2.2 auto hdi estate 52 reg
lurchy666
Re: Xantia hdi rear electric windows and sunroof not workin
sorry forgot to say if i put a live onto the output side of the fuses the windows/sunroof work as they should, so it has lost the live somewhere,
Derekofpriory
Hi, Others with more expertise may be along shortly with other ideas, but having had this problem on our 90 SX V plate it iwas caused by a break in a harness that crosses the front of the car below the radiator, I "fixed" ours by permanently paralleling the broken wire from main fuse box to cabin fusebox.
Cheers Derek B.
Cheers Derek B.
our car spent Friday afternoon and Monday morning in the electrics area of the Factory!!
lurchy666
thanks derek i'll have a look in the morning, i have found a few breaks in the cables on the tailgate while faultfinding why the number plate lights wasnt working, time to get the crimps out again
lurchy666
thanks derekofpriory finally got round to taking the bumper off today and there was a broken cable exactly in the middle of the rad, everything is workin now cheers
