addo wrote: Along such lines, I am sure this fellow would empathise with your balls exploding.
- x 5672
Re: Citrojim's Xantia Tales
Nice if unplanned work Jim, should last a while now
And hoping Malcolm doesn't read this postCitroJim wrote:Today I really am resting
- x 8408
I know, always a big worry...myglaren wrote: And hoping Malcolm doesn't read this post
- x 1490
CitroJim - the only man who considers resting is changing front wheel bearings on a V6 Xantia
- x 8408
Ahh but I was resting Richard... Mike did all the hard graft. I just made tea, operated the press and tapped a couple of threadsRichardW wrote:CitroJim - the only man who considers resting is changing front wheel bearings on a V6 Xantia
vince
- x 13
Hi Jim,
Keeping busy as usual
It will be interesting to see if the replacement lambda cures the fault. I come across loads of these kinds of faults through work speaking to mechanics every day. The problem with lambda fault codes is whether they are the cause or the effect of the problem. We have a new system at work which has been developed by Carweb and is now exclusive to GSF. It has been designed by mechanics and tech people alike to outperform autodata and is taking the industry by storm behind closed doors
If a replacement lambda doesnt cure the fault then if you PM the P code for the fault i can input this into the system and it will walk me through step by step all the possible causes of that code on that vehicle and include how to investigate each avenue. It really is very special in its capability...so much so that autodata have taken the hump in a big way
Im pretty sure i can email the processes aswell.
Im not sure what other sensors are involved in the induction, ecu and fueling system on that engine but often the lambda fault pops up as an after effect of the original cause. It being intermittant definately points towards an electrical issue at some point. Often with these faults, the air mass readings become "unclear" to the ECU....usually air mass sensor or intake manifold pressure sensor if fitted. In these cases the ECU not being entirely sure of the volume of air entering the engine, makes its best guess and tends to overfuel to ensure the vehicle keeps running to get the occupants to their destination. Soot, rich fuel smell and poorer mpg's tend to follow. Emissions are then thrown out of normal levels and if run like this for a long time the lambda in the system, being forced to work outside of its normal working range, tends to either throw up the fault code or fail entirely.
I might be wrong, but thats how most vehicles i come across tend to be behaving. Your ocilloscope would probably come in handy testing individual sensor performances if you cant remotely test them with the lexia.
It will be interesting to see what cures it....
- x 8408
That sounds an interesting system Vince and ideal if you can't interpret what the other sensors are telling you... Just the job for the trade
I can't find anything else amiss on the V6 and as the fault coincides with a recent full new exhaust system I fear they may have damaged the Lambda Sensor then...
Still, we'll soon know...
Problem is, a Lexia on an older Citroen does not give P codes because they're non-EOBD compliant... Be interesting to see how your system might cope with that...
vince
- x 13
usually the tech helpdesk will help link a non p code to get you to the same results if the code doesnt work. If the exhaust has been replaced then you can probably bet the lambda being swapped over has killed it.
- x 8408
It's not been a good week at all. I'm currently off sick suffering severe fatigue and exhaustion. It's a thing that plagues me regularly and brings me to my knees all too often these days...
Due to it I nearly didn't make the DSM Rally this weekend. It was only sheer willpower that got me there on Saturday.
On Sunday, again running on willpower alone, I went to see Chris570 who was suffering a smelly HDi with a diesel leak. The leak was quickly diagnosed to a suspected tiny split in the pipe that runs between the HP pump outlet and the fuel rail. Chris has since replaced the pipe and all is now good. Then it was back to DSM. Truth be told, due to feeling lousy I didn't enjoy it as much as I should have.
From Monday until today it's been a written off week really. Most of it has been spent asleep with the occasional forays into this forum.
Yesterday evening, feeling a tad perkier, I attempted replacing the oxygen sensor on Old V6 and nearly killed myself in the process. I just couldn't muster the strength or concentration needed. The rest of the evening was truly written off. In the end Paul had to do the job under guidance. The sensor was really really tight all the way out and when it eventually came out we could see why. The sensor boss in the new downpipe fitted to replace the complete exhaust a few months ago had a damaged tread and the thread of the old sensor was well mangled. We could also see evidence of violence on the old sensor where they must have really struggled to fit it. It is assumed they damaged it in fitting it. Paul struggled in the new one and on the Lexia we were relieved, nay delighted, to see the new one performing as expected ranging from a low of 80mV up to a high of 900mV over the course of a second and with a much sweeter smelling exhaust
I've put Rattiva to bed for the summer now and brought New V6 into active daily use. Rattiva is my winter car and now winter seems to be over it's time for her to rest and make way for my summer car... I'll miss Rattiva's economy I expect and doubtless she'll see use occasionally when there's a scruffy haulage job needing doing.
Off to see the medical profession on Tuesday to see if they can offer any clue to what's going on. Shame they can't plug a Lexia into me
And again the Activa must wait for new tyres. I've just had to help Robyn out to the tune of quite a stack of dosh to secure her accommodation in Aberystwyth for the next year of Uni...
addo
- Sara Watson's Stalker
- x 95
- x 8408
Re:
Thanks Adam
At least she's noted there's a bit of a pattern going on over the last couple of years and she's a youngster with a bit of enthusiasm going by first impressions. Older and more cynical quacks tend to flinch at any problem that might be above the neck and reach for a box of pills and send you on your way quick. They don't do heads..
Younger and keener ones are generally a little more aware. As always, we'll see
One hopesaddo wrote:quack might have some beneficial input...
red_dwarfers
- x 58
All the best Jim, hope she can gradually retune you back to your optimal settings
Kev
'19 C4 Cactus 130 Flair
- x 8408
Thanks Kevred_dwarfers wrote:All the best Jim, hope she can gradually retune you back to your optimal settings
Citroenmad
- x 110
Sorry to hear you have not been feeling yourself Jim, im sure a quieter week must have done you some good. I hope your feeling back of form again soon.
I didn't realise your HDI was only the winter hack, you'll no doubt be enjoying the V6 to the full all summer. Perhaps that its because your still in your winter car that we are having some interesting, non summer like, weather
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 8408
Me too Chris... It's been going on for a bit too long now. Still yesterday was a definitely better day. I got the house cleaned from top to bottom, tidied up the garden a bit, mowed the lawn and then went to Tesco. I was a bit wrecked at the end of it though and paying for it todayCitroenmad wrote:Sorry to hear you have not been feeling yourself Jim, im sure a quieter week must have done you some good. I hope your feeling back of form again soon.
Well, the indications are that there's a definite improvement in the weather - there's a big, bright yellow ball in a blue sky here at the momentCitroenmad wrote:Perhaps that its because your still in your winter car that we are having some interesting, non summer like, weather
