Xantia HDi - what size ball joint separator for wishbone?
mrjohnson
Unread post by mrjohnson »
The rear bush on one of the front wishbones is starting to go, so I'm going to replace it. I only have a 19mm gap fork type splitter, which won't fit and in any case a fork looks like it will damage the ball joint seal.
Anyone know what size ball joint separator I need? Looks to me like 23 or 24mm jaw width.
Martyn
x 8309
Re: Xantia HDi - what size ball joint separator for wishbone
You need a good one Martyn,
I favour the scissor type. This is a good example...
You also need a big club hammer to go with it as a good clonk from it when the scissor is under tension really helps the joint to separate.
mrjohnson
CitroJim....what width is the slot in this one you gave the link to?
Cheers
Martyn
x 8309
I don't know specifically but as long as it's around three quarters of an inch it'll be OK.
This Franklin one is a very good one.
