Hi all,
Back again, checked pipe work, 10/10 you guys right hand side back and front pipes reversed. Sorted or so I thought, went for a drive in my magic carpet. Got 3.5 miles lost pressure in rear. rear now inactive DOWN ?????????? HELP. P.S. dog bone keeps popping off ?
Many Regards
Nosky.
XANTIA REAR SUSPENSION
Xaccers
- x 186
Re: Xantia REAR SUSPENSION
Should be a metal clip that looks like a bent paper clip that goes over the end of the dog bone. Part No. 529201showing as NFP though.
That is presuming you've got freely moving linkages and a brand new dogbone.
If not then you need to get those linkages free and you need a new dogbone as they wear/crack making them pop off even when everything is working properly.
DIY sphere tool
DIY sphere tool
nosky1954
Cheers Xac, advise accepted, need to get rear suspension working first, see previous !
Regards Nosky
Regards Nosky
