Noticed a couple of times with Cassy when I set the alarm/deadlock with the remote, the indicators come on for a second or so to show it's set, but then the passenger side remains on.
If I unlock and re-lock it's fine.
Must be a dodgy earth, but has anyone had this before?
Xantia Mk1 one side indicators stay on when alarm set
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
- x 5688
Re: Xantia Mk1 one side indicators stay on when alarm set
Yep, mine used to do that.
Never did find a cure.
DickieG
- Monaco's youngest playboy
- x 33
Sounds like a problem with the alarm box under the N/S/F seat (seat out for access), it's worth checking for dampness under there as that causes havoc with the alarm box.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
- x 188
A job for next weekend then
DIY sphere tool
DIY sphere tool
DickieG
- x 33
It might be worth getting the car plugged into a Lexia to see if anything is recorded plus you can carry out a few actuator tests which may reveal a clue or two.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
- x 188
I'll talk nicely to Jim for the weekend after next (I think we may be tackling Cassy's aircon compressor bearing then).
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
ON The head Richard! Thats exactley what it is! Ive had two of these go on me, with exactley this symptom! Swapped the box, problem solved!DickieG wrote:Sounds like a problem with the alarm box under the N/S/F seat (seat out for access), it's worth checking for dampness under there as that causes havoc with the alarm box.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
C5Alan
Gona have to agree with the alarm dieing had this on the merc first one side which I disconected then the other in the end it went tits up and and imobalier was on so had to be disconected no probs now
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
spider
- x 77
I'd concur, it is highly likely the alarm control box. This was not uncommon on early 306's too. Everything worked remote wise but one side indicator would stay alight.
, a new box was about £200 if I remember correctly, there's was located under the right hand front seat.
I never managed to obtain one to examine it to see why it had failed and if it could be repaired, possibly a failed transistor or something simple.
Andy.
Xaccers
- x 188
Does it just control the alarm, or does it handle the remote central locking/dead locking too?
DIY sphere tool
DIY sphere tool
Chris570
- x 36
I'm pretty sure it's just the alarm as the central locking is handled byt the lovely box by the hanbrake. as for the remote, not sure, pass, unplug it and see
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
spider
- x 77
In my experience on a 306 at least, if you unplug it (you have to join a couple of wires in the plug as the starter relay feed goes though it too) the remote locking still works.
The indicators do not light when you lock / unlock and you are unable to initialise / resync any remote keys though (I think)
Andy.
- x 8455
You can unplug the alarm box without issue on a MK1 except...
You'll loose your interior lights as the box also controls their dim-down function...
aerodynamica
- x 216
Yes! I thought I was the only one.. I found that opening and re closing the locks solved it -at first- then after it returned some weeks later the near side indicators all stayed on permanently (even after switching off the engine and locking up)and I could no longer signal left. The only (temporary) solution was to switch off the alarm then pull out the alarm fuse whereupon the indicators all went off but functioned normally upon restarting. Even after a fortnight, putting the alarm fuse back in brought the LH indicators back on.
Graeme M
