Xantia S2 HDI Power steering pipe needed URGENTLY please ?
x 8362
Re: Xantia S2 HDI Power steering pipe needed URGENTLY please
citroenxm wrote: Despite its location and positions, as long as the bracket bolts undo this pipe CAN be removed from the car, and re installed with the gearbox in place, and nothing major needs removing!! It looks worse then it is to do!
Yup, a PITA but not an impossible one...
Depending on where it's gone and if not too near the rubber bit it may well be possible to braze in a new section of pipe. I've successfully brazed before by sleeving the pipe. It really has to come off to do it though...
Else that it's off to Pirtek. Last time I bought this pipe for an Activa it cost £152.
Lighty
x 35
Unread post by Lighty »
I repaired one of these last week, thanks to a bit of advice from PLEIDES.
the ferrule on the end of the rubber section is very thick, so you saw off the metal bit, drill it and tap it out, the screw in a brake pipe flare nut with Citroen fitting. Perfect job, and quite easy really. Should last years once done.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 8362
Lighty wrote: the ferrule on the end of the rubber section is very thick, so you saw off the metal bit, drill it and tap it out, the screw in a brake pipe flare nut with Citroën fitting. Perfect job, and quite easy really. Should last years once done.
Excellent :-D :-D :-D
HDI
x 7
Unread post by HDI »
If and when it ever goes on mine I'll replace the whole thing with a flexible hose !
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Lighty
x 35
HDI wrote:If and when it ever goes on mine I'll replace the whole thing with a flexible hose !
I'd like to see you fit a flexi pipe to the rack pinion [-X
Citroen C15
Citroen Ami
HDI
x 7
You'll need to explain the problem that would cause ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
HDI
x 7
The pipe on Daves car is too far gone to use. If anyone has one or knows of one I'd appreciate it.
Cheers
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Sl4yer
Unread post by Sl4yer »
This pipe has gone on my Activa now. The good news is that the mechanic thinks he's found one. The bad news is, of course, the cost.
Can't believe Citroen has deleted this part, which will send many of the late model Xantias to the scrapper. Then again...
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
harryp
(Donor 2022)
x 73
Unread post by harryp »
Pliades, Pliades!Send off complete old pipe, they tap and supply new pipe and fittings in kunifer. Cost me £60 incl postage and back in 2 days!!!!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
HDI
x 7
He sold the car and bought a 406 !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
