The MOT work is nearly done, but as usual there's a but!
The two larger diameter hydraulic lines that feed the two 'K' connectors at the back are also rotten and need replacing.
Martin at Plaedies can make them but I need to know the length.
Anyone got the measurements I need?
After this it's just the ball joint and she's back on the road.
Ta very much.
Xantia MOT fail/parts numbers needed.
Stepto1
Re: Xantia MOT fail/parts numbers needed.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
- x 1498
I can only see 2 larger pipes at the rear:
From the ABS block at the front to the splitter for the brakes: 4.5mm dia / 3420 mm long
To the anti sink sphere from a K splitter with only 2 pipes (or maybe 3 - perhaps this is where the brake feed comes from - see below!) - 4.5mm dia / 540 long
If these are not the ones, describe the route and I can look the length up.
There's also a long 3.5mm one from a K on the suspension which is the rear brake feed from the rear suspension- this one is 3768mm (and joins onto the connector block on the front firewall).
Stepto1
Oh gosh. The machanic just said it was the two larger pipes that run fwd from the two 'K' connectors.
I'll have to go and speak to him again.
What an epic!
What an epic!
KennyW
- x 165
Any chance of a photo of the connector, from your description I think it is the other K connector which I didn't need to touch.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
Stepto1
Not got a pic and the car is at the garage. He said that there are two of them, one on each side.
