306 and 206 alloy wheel fitment
Welshy_Pete
Unread post by Welshy_Pete »
The alloy wheels fitment diffrence on the 306 and 206 what diffrence will there be?
306
93 to 01
4x108 Pcd
15 to 20 Offset
65.1 Bore
206
98>
4x108 Pcd
20 to 25 Offset
65.1 Bore
spider
x 77
Re: 306 and 206 alloy wheel fitment
Unread post by spider »
Its the offset (I thought that in my head when I read the thread title before I read it)
So the wheels will be further 'in' or 'out' related to where the centre of the wheel hub is.
If that does not make sense, think of it like this, this is just a random example:
You bolt wheel A on and notice there's about 30mm space between the wheel rim inner and the shock tower. You then remove wheel A and fit wheel B, you notice this one has only about 10mm space.
That's the 'offset'
Andy.
