Xac's adventures with Cassy (and friends + wife)
Xaccers
x 185
Re: Xac's adventures with Cassy (and friends + wife)
Unread post by Xaccers »
CitroJim wrote:
Xac wrote: Also need to get seals for the hydraulic pump as it's leaking green blood.
Got gazillions of them Andy. If you can wait till I'm home I'll sort you out...
Do you have one for the bell end?
DIY sphere tool
x 8174
Xac wrote: Do you have one for the bell end?
No, that's the only one I've not got...
Xaccers
x 185
No, that's the only one I've not got...[/quote]
I'll order one from the deer when I order the spring amdnd cup :)
DIY sphere tool
x 8174
Xac wrote: I'll order one from the deer
Would that be the deer in Woburn Safari Park?
Xaccers
x 185
Pesky fingers!
DIY sphere tool
Chris570
x 36
Unread post by Chris570 »
i cannot believe that nobody has commented on this!!!
sorry :P
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
x 8174
sorry :P
Chris, really!!! :twisted: :twisted:
Xaccers
x 185
Chris570 wrote: i cannot believe that nobody has commented on this!!!
sorry :P
I can imagine Malcolm suffering an innuendo overload :naughty:
DIY sphere tool
Xaccers
x 185
More strange cambelt findings with Jenny...
As you can see the old one has a smaller backplate than the new one.
Sent from my HTC Sensation 4G with Beats Audio using Tapatalk 2
DIY sphere tool
Xaccers
x 185
A productive afternoon, cam jockey replaced, aux belt auto tensioner fitted, water pump fitted (the old one didn't have the metal shield!) and new anti-freeze added, 19mm O-rings in the hydraulic pump replaced.
Tomorrow, if I can pop over to Jim's and borrow his sphere tool, I'll be fitting Cassy's old strut tops. Also need to pop to Maplins and get some grommets as I'm going to remove Jenny's headlights, drill two holes in the underside and do the relay mod internally.
Hopefully I'll get a chance on Monday to call the local dealer and order the dealer only bits I need.
DIY sphere tool
x 8174
I'll be in Andy so please do pop over...
Xaccers
x 185
CitroJim wrote:I'll be in Andy so please do pop over...
Great, thanks Jim :)
DIY sphere tool
Xaccers
x 185
Strut tops have been swapped over. Jenny's aren't too bad, but there's a fair bit of rubber missing and surface rust, whereas Cassy's are just losing the thin run of rubber around the edge in a few places.
I'm wondering if this early on in their deterioration using some rust arrest gel and silicon sealant would prevent it getting any worse?
When I did the N/S strut, I put my tray underneath to catch any errant LHM.
I heard a running liquid sound, more than the dribble of LHM the strut should make so I had a look under the car.
Gearbox oil was pouring out of the N/S drive shaft.
It looked old and dark, a bit like the LHM to be honest, so It looks like the drive shaft seals need replacing, along with the oil, and I'll do a hydroflush too.
Didn't manage to get to Maplins so didn't do anything with the headlamps this weekend.
DIY sphere tool
x 8174
Ahh, it's been a day of epic spills then Xac :lol: :lol: :lol: See my blog for my tales of spilt fluids :lol: :lol:
Get some Waxoyl going around those strut tops, that'll arrest any further for now...
It's so easy to dislodge that driveshaft. We managed it when we did the ABS reluctor on Rattiva...
Xaccers
x 185
How easy is it to replace the seal?
DIY sphere tool
