Ever wondered whats behind the upper rot???
bxzx16v
x 35
Re: Ever wondered whats behind the upper rot???
Unread post by bxzx16v »
Here's a few pics of a Dutch Zx16v with serious rust issues
Very nasty , the car in question was broken for parts then crushed , my Zx16v is a similar age but with virtually zero rust , I suppose too it depends if the car was used much in the winter months and if so jetwashed underneath to remove road salt & crud build up .
Mark
waynedance
x 8
Unread post by waynedance »
Rust I hate it, it would drive me up the wall to have rust on my car.
Hope the C5's don't rust !!!
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
youd better remove your underbonnet plastic covers over yur strut tops then waynedance, the tops appear to rust very badly!!!
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
bxzx16v wrote:Here's a few pics of a Dutch Zx16v with serious rust isues.
Mark
ah but zx's are known for rusting badly in cills and floor out riggers etc.. the point im making here is the "some do some dont rust " xantia ONLY owners, have got or gettin in an upper layer of metal...
A very sad...
1994 XM 2.1 d auto
waynedance
x 8
citroenxm wrote:youd better remove your underbonnet plastic covers over yur strut tops then waynedance, the tops appear to rust very badly!!!
Ok going outside now to check, you say strut tops, is this under the bonnet?
Citroenmad
x 110
Unread post by Citroenmad »
waynedance wrote:Rust I hate it, it would drive me up the wall to have rust on my car.
Me too, rust is a pet hate of mine, once it sets in its very costly to put right.
C5s don't have rusting problems at the moment, perhaps when they age more they might but generally Citroens hold up very well if they are looked after. Xantias are hardly rot boxes, but this area is the worst.
I can see C5 sills potentially being an area to keep an eye on, behind the plastic sill covers but under the sill, a couple of very early cars I have seen have had surface rust there.
Yes, some strut tops do look quite rotten, again on early cars. I have not heard of one failing but they can get surface rust. My middle C5 was quite bad with rusty looking strut tops and the sills on the underside of the car was getting surface rust, nothing to worry about as its very thick metal and was only surface/paint rust. Our 2002 C5 had brilliant strut tops, no corrosion in sight, as with our C5IIs, however I given them a spraying with some rust preventing fluid on every service inspection.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Citroenmad
x 110
Yes, pop of the plactis covers both sides (small one on the NS and large one which covers coolant and LDS tanks on the OF) and you will see the strut tops. Check if they are rusty, I would spray them with some rust preventing stuff while your there.
As I say, never known a C5 strut top fail, but you dont want rust in that area.
03 Seat Arosa 1.0S
waynedance
x 8
removed those covers before and all is good. :-D
love my C5, hope it lasts for years to come.
citroenxm
Fallen Hero
x 70
.nice one wayne.. they should do with care.
thing is.. this v6 only has a calculated 75k on it.. but my xantia s2 now with 209k does not have any of these rust issues... they are sooooo hit and rust missed at the moment!
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
Thats good news :-D
Here are mine:
I would keep an eye on them and keep them rust free!
03 Seat Arosa 1.0S
robert_e_smart
x 14
Unread post by robert_e_smart »
C5s with the plastic covers need to be watched. One of the front sill covers on my folk's C5 got knocked loose at the bottom. I was amazed at the amount of small stones and dirt that had got trapped between them and the sills. The car had only 80K miles at this stage. There is also a lot of other plastic panels under the C5 as well. Where these panels meet metal, you are asking for rot.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 5674
Citroenmad wrote: I can see C5 sills potentially being an area to keep an eye on, behind the plastic sill covers but under the sill, a couple of very early cars I have seen have had surface rust there.
My 'new' C5 had part of the sill cover missing and I was pleased to see that the sill was completely intact and free from rust.
Pinched the corresponding piece from the estate and that was fine too.
Citroenmad
x 110
Yes, ive had the sill covers off the C5s and cleaned them out.
03 Seat Arosa 1.0S
Dommo
x 20
Unread post by Dommo »
citroenxm wrote:There you go Chris... you just said it.. yours is a non sunroof car and going in that area... :?
My R reg s2 2.1TD had rust - none sunroof model
My R reg s1 (but is a 95 car as far as I can make out, just late registered) 1.9 doesn't have rust there - sunroof model.
My T reg s2 activa was a none sunroof model, and wasn't rusting there...
(all hatchbacks)
Norlander
Unread post by Norlander »
Same on our (2002) C5 ... removed the sill covers and gave the sills a clean and
a coat of Dinitrol. No rust, paint undamaged. Renewed the plastic fixers while at it.
