Xantia spheres in Ireland
Eddie99
Unread post by Eddie99 »
Hi everyone,
Many years ago in London I had a CX, eventually it sat down and would not get up again!!
I now have an old Xantia. I need to sort out the rear suspension and I need even just 2 spheres for the back just to get it some way drive-able.
Is there any place in Ireland that the spheres can be got easily?
I was hoping for somewhere around Cork.
411514
(Donor 2017)
x 39
Re: Xantia spheres in Ireland
Unread post by 411514 »
Most people on here seem to recommend AEPdirect. They seem to be the cheapest around of satisfactory quality, although probably not of the same quality of an oem citroen part from the dealer, sam
Sam
2003 C5 2.0HDI 110
Eddie99
Thanks Sam for your advice, I will look there.
Regards
davoxx
x 15
Unread post by davoxx »
does the back rise up?
why?
robert_e_smart
x 14
Unread post by robert_e_smart »
Eddie, try your motor factor, they should be able to get them for you. Worst case get GSF in Dublin to mail them down to you or your mechanic.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Eddie99
@davoxx
yes the car rises and lowers to the correct levels.
I have added half a litre of lhm and just rechecked it - it is not leaking.
The rear suspension is very bouncy when on the road, like if the rear spheres are faulty.
I had a look underneath and the 3 rear spheres look old, the middle one is rusty, so I might be better of changing the 6 of them.
Eddie99
@robert_e_smart
Thanks for the suggestion Robert,
I will try locally but might get them sent to me from AEP Direct,
Will be in Dublin next week and might look in on GSF.
