Headunit
Richard Gallagher
user_3150
- New User
Richard Gallagher
Discs are rarely difficult to replace, but you will need a large torx bit, I think its size is 40. After all the usual jacking etc you will need to remove the caliper support bracket, just two bolts then undo the disc retaining screws, usually rusted in, if so use a hammer and chisel and gently tap aroung then whilst someone else applies some effort at unscrewing them (cheap method if you do not have an impact driver!).
What you will need to do is to screw the caliper pistons back into the caliper. If you do not have the correct tool (Caliper wind back tool) then use a square shanked screwdriver and be patient. Also don't allow the caliper to 'dangle' on the brake pipe, always support it.
Always fit new pads with new discs, then remember to apply the footbrake to push the pistons back against the new pads before driving. (It makes for a good laxative if you don't!!!!)
