What's currently wrong with your Frenchy?
R9UKE
- x 3
I just thought this would be interesting, and perhaps make me feel slightly better about my never ending to do list. What is currently wrong with your car(s)?
Here's mine to kick things off!
The Mégane Privilège:
4 tyre pressure sensors need replaced
Slow puncture in one tyre
"Hands Free" locking button on the drivers door handle has stopped working
Fidgety rear end (yet to be diagnosed)
The Avantime:
CD Changer has given up
Another slow puncture
Drivers heated seat not working
The Clio Alizé:
Fuel light stays on ALL the time
The Laguna V6:
Odd creaking sound from the front suspension
The Mégane Dynamique:
I can only dread what faces me after three months lying around at the so called repair centre.
The Clio RT:
Well, it's had it's day to be honest
1st and second gear now almost completely absent, making it very difficult and noisy to drive anywhere, unless it's in reverse
Starter motor needs a good whack with a spanner to work
Front nearside shock absorber gone
Fuel gauge not working
Heater not working
Brake discs warped
It's also starting to use coolant
.... retirement time me thinks!
The Avantime:
The Clio Alizé:
The Laguna V6:
The Clio RT:
Heater not working
Brake discs warped
French is best.
addo
- Sara Watson's Stalker
- x 95
- x 8422
Re: What's currently wrong with your Frenchy?
V6
Needs a pair of front tyres, else fautless
Activa
Peeling lacquer on roof
needs new tyres
Slight weep from rear ram
Rattiva
Replace ratty gearbox but no rush, got no worse in 4,000 miles.
Turn heater from a binary one to an analogue one... It's presently either on or off...
Treat it to a proper new set of spheres.
Repair hole in drivers seat...
Activa
needs new tyres
Rattiva
DickieG
- Monaco's youngest playboy
- x 33
Nil return for me
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8422
I was going to say that's because you're retired and have loads of time to attend to all things automotive but that's not quite true now is it?DickieG wrote:Nil return for me
If I had more time I'd have made a nil return too...
Deanxm
- x 87
Activa
put the xm's Perelli P Zero's on the activa
Repair quadrant plate
XM
put it back together with new insulation and cavity/underbody rust prevention
Fit headlamp washers
New ARB bushes
XM
New ARB bushes
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8422
Spoke too soon
Massive LHM leak from the front ram on the Activa...
They have ears (or read the forums)
red_dwarfers
- x 58
WOR
Coolant decided to go on holiday a few days ago
Having taken off my rose tinted specs, it seems the lacquer peel isn't just on the spoiler, it's on the bonnet and roof too
RCL stopped working yesterday
RUNN
Wiper rubber broke, now replaced
XM
Engine fusebox needs replacing (have a new one in stock to fit) and blower fuse upgrading to 40 amp
RCL not working
Airbag light has just started flashing
Parent's Astra
Pretensioner light on, Dad found that if he wiggled the connectors under the passenger seat it went off, where do I remember that from
Old man's Yamaha Diversion
Broke down for the first time in 16 odd years, water in the tank
Oil leak
On the plus side though, he's just resprayed it and it's looking really smart
RUNN
XM
RCL not working
Parent's Astra
Oil leak
Kev
'19 C4 Cactus 130 Flair
R9UKE
- x 3
This is what terrifies me about having a Citroen lying around. Robert was telling me how he moved one the other day and it starting hissing at him and secreting a green liquidCitroJim wrote: Massive LHM leak from the front ram on the Activa...
The easiest Renault fix of them all... works every time!!!
French is best.
Xaccers
- x 188
Cassy
Needs an oil change - tomorrow
Needs new front brake pads - tomorrow
Lacquer peeling
Rust patch by rear N/S door/arch that needs cleaning up
Jenny
Replace bumpers
Replace bonnet
Replace wings
Replace rear O/S door
Swap around rear wheels
Fit new battery
Give service
Change cambelt
Juliet
Replace front N/S door
Replace rear tyres
Tackle rust on rear N/S quarter
Sell
Lacquer peeling
Jenny
Replace bumpers
Replace bonnet
Replace wings
Fit new battery
Give service
Change cambelt
Juliet
Replace rear tyres
Sell
DIY sphere tool
DIY sphere tool
- x 8422
All part of their charm and character Luke...R9UKE wrote:This is what terrifies me about having a Citroën lying around. Robert was telling me how he moved one the other day and it starting hissing at him and secreting a green liquidCitroJim wrote: Massive LHM leak from the front ram on the Activa...
They have ears (or read the forums)![]()
- x 94
its turned red and calls itself a TZD BX
the XANT is taking a rest/SORN till i decide to fix her up/maybe,
regards malcolm
regards malcolm
waynedance
- x 8
ermmm let me think.....
oh yeh a very very very slight creaking noise from the n/s/r door trim, that's it my car runs sweet.
I must confess that if anything was to go wrong like a warming light on the dash, tyre pressure sensor or such it would be sorted the next day if not the same day, hate faults with me car has to be near 100%.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
red_dwarfers
- x 58
I'll have to remember that next time I see you. In my mind at the moment White Xantia Estate = Mr and Mrs Citronut, not sure anything else would computecitronut wrote:its turned red and calls itself a TZD BX![]()
regards malcolm
Kev
lexi
- x 133
I have given up chasing quirks. My Vel Satis goes stops heats and starts. Suspension brakes and oils all good.
What don't work on it I don't need. Sat Nav and cd..........I don't even use a radio
There is enough working on it to satisfy me for a while. That'll do me. The run I do mainly with it is giving 33mpg on computer.
Well pleased.......it oozes character!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
