Hi all deoes anyone have the spec sheet for changing the timing belt on the 2.0 hdi 8v?
at the moment i dont have anything regarding timing and locking tools needed
many thanks
bick
relay 2.0 hdi timing belt info?
- x 1240
Re: relay 2.0 hdi timing belt info?
Hi Bick
I think the Haynes manual will give you the info you need.
- x 1489
Info in this thread: http://www.frenchcarforum.co.uk/forum/v ... 11&t=33939
It's based on a 110 Xantia, but the principles of the belt are the same. Note that if it car is after early 2002 then the vernier cam pulley was deleted in favour of a floating crank pulley. On these you need to time the engine before undoing the crank bolt, so a crank holding tool which engages with the ring gear is essential.
Bick
- x 43
thank you both for the quick reply
bick
bick
