cost of matrix replacement
Ozzie Kuma
Re: cost of matrix replacement
Unread post by Ozzie Kuma »
thanks for that citronut,.. just what I wanted to hear after the 123 hours, ripped fingers, stiff neck, broken back I have spent on this damn thing. My other beast is 3 years older than this & has not leaked a drop for the matrix !!! Hope I am lucky again. Still we Ozzies don't get the extremes of Pommie weather, probably helps it to last longer.
98 Xantia V6 MK2
95 Xantia VSX
Harry1975
Unread post by Harry1975 »
im doing mine next week, plus im doing head gasket took the head off yesterday ,and yep the gasket totaly worn out, only the metal rings and outer edges left, i was surpised it had not gone sooner, engine ran fine, just a load of steam .
lexi
x 134
Unread post by lexi »
Having looked at all this ,is there anything to add for the V6? Not putting my hand up yet mind :oops:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You can drive with a lot of it removed:
I've even got the whole darned HVAC box out now, and that metal hoop that braces off the fuse bloc. Tempted to plug the radio back in for grins. Wipers are back on for usability.
Only "bugger, bugger, bugger" moments have been finding the Ford style AC inline connector (I don't have the tool and it was Sunday evening) plus losing a 10mm deepwall socket into the subframe's darkest recesses, along with a flanged nut, and two washers. All except one fibrous washer were found...
x 8364
You could start a new trend, driving around like that Adam :-D :-D :-D
Quite a respectable 'kilometerage' you've clocked up there...
addo
x 95
There is a nest of black ants in the car. They timeshare (depending on season/weather) between that box section the dash studs pass through (in picture) and under the roof rails.
Mr Pyrethrin will be speaking to them soon.
x 8364
Re:
addo wrote:There is a nest of black ants in the car. They timeshare (depending on season/weather) between that box section the dash studs pass through (in picture) and under the roof rails.
:rofl:
At least they're not green ants :twisted: We had green ants the size of of cats in Darwin..
Not as bad as the tree frogs that used to live in the downpipes on our house .They used the pipes as amplifiers... Gosh it was a noisy place at night...
When we came back to the UK we were deafened by the night-time silence and had trouble sleeping, especially Robyn... I'm pretty sure as she was born into the chorus of tree frogs, crickets and cicadas she missed it even more than we did...
x 94
Unread post by citronut »
Harry1975 wrote:im doing mine next week, plus im doing head gasket took the head off yesterday ,and yep the gasket totaly worn out, only the metal rings and outer edges left, i was surpised it had not gone sooner, engine ran fine, just a load of steam .
bit extreme removing the head just to get at the heater pipe connector, well maybe not :shock: :twisted: :lol: :wink: ,
regards malcolm
x 94
Re:
addo wrote:You can drive with a lot of it removed:
id just by a better quality of matrix :shock: :twisted: :wink: rather than leaving all that off for the next time you have to fit another one #-o :wink:
regards malcolm
x 8364
citronut wrote:well maybe not :shock: :twisted: :lol: :wink: ,
Not at all Malcolm, the better access to the elbow afforded by removing the head will make it very easy to separate without damage :-D :-D
And driving around with no dash in does make the job easy next time... :lol:
addo
x 95
Through fixings reached from scuttle side. Wiper mechanism removed for clarity.
Yes, I have not yet cleaned that intake grille.
VertVega
x 13
Re:
Unread post by VertVega »
addo wrote:You can drive with a lot of it removed: ...
Above there is one of the best pic of a Xantia I've seen Image
Edit: ... and this pic below with navigator is even better :-D
addo
x 95
Soundproofing has lost some of its "skin" wrestling with the HVAC box.
ashy90
Unread post by ashy90 »
LOL. Reminds me of when my dad drove a Fiesta with no front carpet (cut it instead of removing seats etc. when it needed welding in the floor.
addo
x 95
There is no front carpet either.
I have examined the old matrix and yes - it definitely leaked from the junction of plastic header tanks and extension tubes. The O-rings were hard and cracked.
With the Nissens matrix, I removed this extension piece, cleaned the assembly oil from O-rings and fittings, then reasembled with ThreeBond 1211 plus the O-rings! The idea was to fill that void between the O-ring and plastic moulding's internal shoulder, adding a measure of extra protection.
In future, I would trim the extension's header plate and plastic weld the tubes to the header tank. It's only the complications of shape that make injection moulding the whole shebang in one piece, unworthwhile for manufacturers.
