Xantia wishbone bushes replacement frequency
x 8422
Re: Xantia wishbone bushes replacement frequency
Dommo wrote:
Mandrake wrote:The idea is to have the bushes under no torsional stress at the normal ride height...
I've often wondered how the bushings on sinkers cope with this, as the bushings must be under constant load when sunk down?
I've often pondered this Dom but I guess it's because they're under a static load and not continually flexing at a point of great torsional load. Whatever the reason, they last OK...
red_dwarfers
x 58
Unread post by red_dwarfers »
Do sinkers sink at the front, I had always assumed it's just the rear.
Kev
'19 C4 Cactus 130 Flair
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
red_dwarfers wrote:Do sinkers sink at the front, I had always assumed it's just the rear.
Yes they do sink at the front.
If the bush is centralised then it will never be taken beyond its designed limits, if not then even with a non sinker the bush will at some point be pulled beyond that point as the suspension is fully extended or compressed.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8422
I've an HDi that sinks at the front, just like a proper sinker :-D
x 94
Unread post by citronut »
that'll be the BX especially when the dosour valve is leaking internally :shock: :wink:
regards malcolm
c.morewood
x 55
Unread post by c.morewood »
Well thats the new o/s bush on.. We'll see how long it lasts.. bough a pair of secondhand wishbones fron Robert on this forum, hopeing to do a straight swap, but on close inspection they were starting to go as well. but they were invaluable in gettng the correct angle for the bush and in enabling me to do the whole job in less time.
I also found that long cable ties helped immensely in holding things out of the way during removal and fitting.. they don't tire and get bored as easily as 15 year old boys!! :-D
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You just needed a picture of Cindy Crawford or someone similar, taped inside the wheelarch to maintain your lad's attention span.
Were your own old bushes appreciably misaligned, compared to the unmolested arms?
c.morewood
x 55
Yes addo I'm afraid they were and well well beyond their best before date!!
Possibly as much as 10 degrees.. I didn't really appreciate the accuracy required last time and didn't use a completely flat surface to line up ( the garage floor) Whereas this time I used the flat metal bench.
'94 Fiat TipoTd 40K
x 94
i would think it is hard to tell were the old bush's were aligned to if they have fully ripped away from there center's,
i have seen them so bad they are completely un/bonded from the center sleeve,
regards malcolm
addo
x 95
citronut wrote:i have looked under Adam's car recently.
regards malcolm
x 94
regards malcolm
:^o ou i never said that, its shear fabrication :-D :wink:
i thought you keep your cars properly maintained Adam
regards malcolm
Deanxm
x 87
Unread post by Deanxm »
My P's are shot again now, one pair i got from ebay were too big for the wishbone and just slid on and off by hand and wobbled about they were so bad, the weld broke on the usable one from that pair that was the right size when in use too, the other came from local factors and is of really soft compound, when you come to a halt the wheel stops and the car rocks forward on the play in the soft rubber compound in the bush, utter rubbish, as always get genuine and all will be well, they are more expensive for a reason, same as CV gaitors and ball joints imo.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 1471
Unread post by xantia_v6 »
Deanxm wrote:, as always get genuine and all will be well, they are more expensive for a reason
D
So where do you get "genuine" bushes?
service.citroen only lists them as part of the arm assembly, over £300 for both sides.
[edit] OK, cross referencing via the oracle of ebay, the citroen part numbers are 352382 - 352381 - 96083570
about £100 for a set.
Are the GSF ones on ebay any good at half the price?
addo
x 95
Half as good? :shock: They (GSF) may offer "premium" grade ones in the way they do with some suspension hardparts.
I - or someone else - need to design a simple jigging board so the arm may be laid out and P bush started in correct alignment.
x 1471
Re:
addo wrote:Half as good? :shock:
I'd be happy with that. The originals have lasted 190,000 miles, I don't think the rest of the car has another 95,000 left in it...
