C5 Slow pickup.
Alec B
C5 Slow pickup.
Unread post by Alec B »
Hi our C5 1-6 HDi doesn't pickup well at all from standing and changing gear. I have seen some posts on EGR valves but am not too familiar with them. Would that be the likely cause and how easy are they to get to and service? By the way we are getting no errors on dash and all lights go out as soon as car has started. My wife said it also stalls if rev's aren't kept high on pull off. Is there anything else to check? Also if travelling at low revs i.e 5th gear @ 50mph you can feel it hesitating. Any ideas?
Current Car
C5 Estate VTR 1.6HDi 2005 S2
Previous French Cars
Pug 205 Gti 1.6 1985.
Xantia Estate LX 2000 90bhp HDi
Xsara Picasso VTX 1.6 HDi (92) 2007
Citroenmad
x 110
Re: C5 Slow pickup.
Unread post by Citroenmad »
It sounds like a possible MAF sensor fault rather than EGR problems. You could remove the sensor and give it a clean with electrical contact cleaner. Or replace it with a known good one for testing. A Lexia should be able to tell you any faults as I bet it has stored a code despite not putting a visual warning on the dash.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Irish_C5
Re: C5 Slow pickup.
Unread post by Irish_C5 »
Mine is slow to pick up too, but only when the revs are under 1500. I just presumed that the engine doesn't have as much torque as my 2.0 406 and it's also a heavier body.
x 5662
Re: C5 Slow pickup.
Agree with Chris that this is indicative of a MAF sensor defect.
Alec B
Re: C5 Slow pickup.
Thanks for the replies. I'll take a look this weekend as I have a bit of a to do list and this can be added too. Just a quickie where is the MAF sensor on the C5? Thanks.
Current Car
x 5662
Re: C5 Slow pickup.
Immediately after the airbox.
Image Image Image
click image for a larger one.
It is the thing with the grey electrical connector adjacent to the gap between the battery and fusebox.
DON'T touch the two wires inside, or drop it.
Citroenmad
x 110
Re: C5 Slow pickup.
Im pretty sure it is similar on the 1.6HDi.
As Steve says, dont touch the sensor inside but you can clean it with an electrical contact cleaner spray. The blast it with as air line if you can.
The 1.6s ive driven have not been flat below 2000 rpm, so it would seem there is somehting not quite right.
03 Seat Arosa 1.0S
Alec B
Re: C5 Slow pickup.
Thanks for the pics and help, another job for the weekend! Carlsberg don't do car forums but if they did.....................
Current Car
Citroenmad
x 110
Re: C5 Slow pickup.
Alec B wrote:Thanks for the pics and help, another job for the weekend! Carlsberg don't do car forums but if they did.....................
We aim to please :lol:
03 Seat Arosa 1.0S
