Citroen Suspension overhaul
paranoid
tony42
- x 4
Finally replace my LHM today with Hydraclean. Took me about 4hrs and I only managed to bleed one caliper as I ran out of time.
For me it worked fine. I left all the hoses connected as suggested by the Black Sabbath fan and i had no problems repressurizing the system.
Had no problem with opening the bleed screw on the brake caliper but bleeding the brakes were awkward by myself as the bleed screw is locating beautifully to make it difficult to get a spanner and a bleed kit on to it.
Doesnt seem to be any air in the system as the brakes are working fine but I intend bleeding the 2 rear and 1 front caliper over the next few days just to get the old stuff out.
Very pleased that everything went ok and the instructions were great
Tony
Tony
BonceChops
Tony,
What method of brake bleeding were you using?
I bled mine like this -
1. Remove wheel.
2. Put 8mm ring spanner on nipple.
3. Put PVC pipe on nipple and other end into a container.
4. Start engine and push brake pedal down with a piece of wood wedged between pedal and drivers seat.
5. Open bleed nipple and watch fluid fill container. ( make sure LHM level is ok )
6. Tighten nipple and remove pipe.
7. Turn of engine.
8. Refit wheel.
9. Check LHM level.
And finally in good Haynes style - Complete the other 3 brakes using the same method.
Hope this helps.
1. Remove wheel.
7. Turn of engine.
8. Refit wheel.
9. Check LHM level.
Hope this helps.
John F
Kowalski
For step 2, In preference to an 8mm ring spanner, I would use an 8mm 6 sided socket. Where I have used a 6 sided socket and a ring spanner (12 sided) and lots of force on 24mm nuts on my tow bar the ring spanner damaged the nuts where as the socket didn't even mark them.
Waterproof grease tends not to be as good a lubricant as normal greases, however it doesn't dry up and won't get washed off very easilly. Under the gators on a Xantia you won't get a lot of water, so it doesn't matter about being water proof, and an LHM under there would keep the grease wet, so all in all there is probably no point using a waterproof grease.
tomsheppard
Kowalski
tomsheppard
tony42
- x 4
Stopped reading the instructions when it came to the bleeding.
I didnt use the block of timber which would have been sensible so hence a major cause to my hassles with it.
Not trying to lower the level of coversation but i had trouble with releasing the nipple and keeping the pipe over it. Thanks for the timber idea i had forgotten that part.
Have to say still not fully happy with suspension. new spheres greased struts and now hydraclean but still feel its not quiet what it should be. I will wait to see how the hydraclean works and maybe grease struts again. After that I will maybe investigate height correctors. Not too sure what I have to do I am assuming there are parts that can be cleaned and greased once the car is supported by axle stands or trolley jacks
Tony
Tony
