How wide is your clutch pedal?
Xaccers
x 188
Unread post by Xaccers »
Cassy's clutch pedal rubber is splitting, so a few months back I went to the local dealer and ordered a replacement, it looked a lot smaller than I remembered her pedal being, and putting it against the pedal shows that yes the part which service.citroen says it should be is much narrower. I put it down to the parts bag having the wrong number on it.
Going for the MoT yesterday, I thought I'd nab Jenny's rubber, but that too is much narrower.
Did estates have larger clutch pedals (similar to the brake pedal size, just a mirror image), or could Cassy have had her pedal replaced with maybe an XM one in her past?
So how wide is your clutch pedal?
DIY sphere tool
DickieG
Monaco's youngest playboy
x 33
Re: How wide is your clutch pedal?
Unread post by DickieG »
In late 95 Citroen increased the spacing between the clutch pedal and the transmission tunnel so maybe your car has the earlier design and you've been supplied with one for a later model.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
Unread post by citronut »
service citroen only lists one across MK 1 and 2 all modles except houcamatics :shock: :twisted: :lol: :wink:
2130 13
PEDALE COVER
regards malcolm
x 2938
Part number 2130.13 for early cars andit seems all LHD cars.
2130.15 RHD cars from date 03/03/1997.
Xaccers
x 188
So it looks like 2130.13 is the larger pedal?
DIY sphere tool
x 2938
Looking at the pics it seems to be but the main difference is that the .13 one is rounded down both sides and the .15 one is rounded on the right side and has a diagonal cut off on the left side.
x 94
ok i clicked the LHD by mistake so it seems all MK1 and 2 LHD end 13 and all MK1 and 2 RHD end 15,
regards malcolm
