the unit thats attached to the sphere on the front of the car.
according to haynes manual its the hydraluic regulator but according to citroen dealer its the anti sink valve
any way its leaking and getting worse so can anyone tell me if there is a seal kit for or can you get seals to fit.
regards
nick
LHM Leak
pete the bus
Re: LHM Leak
It's the pressure regulator. It leaks when the attached accumulator sphere is flat. Check to see if you can hear a regular ticking coming from the regulator. If it does, the sphere is flat. Changing it might stop the leak. If you want to have a go at repairing the seals on a regulator, there is info here:-
http://www.frenchcarforum.co.uk/forum/v ... hp?t=34300" onclick="window.open(this.href);return false;
- x 1240
Re: LHM Leak
I believe there is also a rubber return pipe on it which can split and leak - there is on the XM anyway.
nick90
Re: LHM Leak
changed the sphere yesterday leak is gone
thanks for advice lads
- x 8325
Re: LHM Leak
That's a nice result Nicknick90 wrote:changed the sphere yesterday leak is gone
