A few Xantia HDI questions.
addo
- Sara Watson's Stalker
- x 95
Stepto1
Re: A few Xantia HDI questions.
I know what you mean about the flickering lights. But this isn't a flicker, the red led and red STOP light flash at about one flash a second.
I've checked the level and it looks ok.
I wondered if it was the low level alarm?
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
DickieG
- Monaco's youngest playboy
- x 33
Does this occur with the A/C turned on but stop when the A/C is off? If so it's quite likely down to a fault with one or both of the cooling fans, they should both in tandem whenever the A/C is turned on, if not then let us know and we'll give you a few pointers of how to diagnose the problem.Stepto1 wrote:I know what you mean about the flickering lights. But this isn't a flicker, the red led and red STOP light flash at about one flash a second.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Stepto1
Ah, I think it might only happen with the A/C on. I'll check.
- x 8414
Pop the A/C on Stepto and see if both fans are running at slow speed.
If not, try poking them with a stick and see if that provokes them into running.
Often the brushes get a bit tired and sticky and a small poke often gives them just enough encouragement to start running.
The problem with the HDi is that the fans so rarely run to cool the engine that if the AC is not regularly used the fan motors die through pure lack of use...
beast
Hi I've got exactly the same problem as stepto the stop light flashing alternatively with the coolant warning light it comes on without the ac on its also the HDi model
Stepto1
Oh no, it's contagious!
Stepto1
Ok. Air con on, lights flash, neither fan turns.
Air con off, lights stop flashing.
There's the problem!!!
Stepto1
Ok. Just come back from a run out. A strange thing happened.
It started fine but when I came back I tried to restart it and the starter hardly managed to turn the engine over. It got slower and slower, then I heard voices......
The Trafficmaster woman had been raised from the dead and was telling me my contract was out if date.
Then, as the engine turned over on the starter, I could 'hear' the starter over the radio!!
At the same time, all the lights flashed on the dashboard and the speedo and rev counter started waving at me!!!!
Then, all this stopped, the starter picked up speed and the car started fine????
Answers on a postcard please?!?!
Chris570
- x 36
did you check if the battery terminals were warm?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Stepto1
They seemed cool enough to me while the engine was running.
I'm guessing the alternator is ok but the starter AND solenoid are trout.
Chris570
- x 36
well if the clamps have got high resistance it'll cause all sorts of fun and games when you've got a high current being drawn, is my thinking, i'd check it just after cranking
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
Stepto1
Ok, will do. The clamps look original, they're well greased and the battery is brand spankers.
Chris570
- x 36
Mine weren't getting much warmer than ambient but i still replaced them and since then i have faster cranking
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
Stepto1
Ok, just had the Fluke out. Across the battery terminals, the voltage reads,
12.6 with engine off.
14.2 with engine running just after starting.
13.6 with engine running, all accessories on and about 5 mins after starting.
Battery leads were cool at all times.
I'm putting the problems down to a duff starter.
Although it's just started at least 20 times in about 5 mins with no problems. (accept Trafficmaster woman. How do I shut her up???)
