Hi to all, our C5 tends to wander when in a straight line on uneven roads sometimes to the point of needing to correct it. Tyres all ok, balanced, pressure, tread etc. It feels as if it's coming from the power steering which has a mind of it's own any ideas?
Thanks Alec
Wandering C5
Alec B
Wandering C5
Current Car
C5 Estate VTR 1.6HDi 2005 S2
Previous French Cars
Pug 205 Gti 1.6 1985.
Xantia Estate LX 2000 90bhp HDi
Xsara Picasso VTX 1.6 HDi (92) 2007
Lighty
- x 34
Re: Wandering C5
Worn rear arm bearings will cause this, rear end steering .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Alec B
Re: Wandering C5
Ah cheers. I take it this is a common problem as it's only done 50'000 with no towing. Is it also a simple (and cheap) job and what's the easiest way of testing the rear arm bearings? Phew sorry for all the questions. Regards
Current Car
cachaciero
- x 9
Re: Wandering C5
Certainly a not an uncommon problem on Mk1's My feeling is that it largely emanates from the back due to the passive rear wheel steering set up and I always thought that the Mk1 was more susceptible because Citroen cocked something up on the Mk1 rear axle although what was never clear, at least to me. Personal belief is that the drillngs for the arm bearings was out of tolerance probably resulting in incorrect or marginal rear wheel alignment. However my belief is that this must have been rectified on Mk2's as the axle tube is a different part number.Alec B wrote:Ah cheers. I take it this is a common problem as it's only done 50'000 with no towing. Is it also a simple (and cheap) job and what's the easiest way of testing the rear arm bearings? Phew sorry for all the questions. Regards
I have noticed on mine that it is very sensitive to tyre pressures as much, if not more, on the rears as the front, I also find that it is better running the tyres over pressure 38 as opposed to 33,
Arm bearing failure is usually audible i.e creaks and groans and the rear wheels tend to show pronounced camber, however there are quite a few reports where bearing failure has happened silently and my belief is that they would have to be well shot before camber changes became noticeable.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 1240
Re: Wandering C5
Are the front tyres wearing evenly? Uneven wear can cause this.
Alec B
Re: Wandering C5
Thanks for replies. I will try a higher pressure as the rear arms, as said, don't creak or groan. The rear tyres wear evenly but the front's do wear on the inside. I think the cheapest option for now is higher air pressure and maybe a 4 wheel alignment. I hope this cures it as I've found some old posts and it doesn't look like an easy or indeed cheap job. Funny when I first bought my Xantia I had a similar problem but it resulted in me getting very tired when driving and that was tyre pressures having to be spot on.
Current Car
cachaciero
- x 9
Re: Wandering C5
If the front tyres are wearing on the inner shoulder I would suspect that the tracking is incorrect, i.e toe'd out, this would almost certainly provoke a degree of wandering.
My own experience and most comments I have read would suggest that outer shoulder wear is the norm on these cars.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Jabo
Re: Wandering C5
Mine veers to the left when driving and at least one of my rear arm bearings is needing replaced.
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
