The warning light on the dash is constantly on. I have searched for and read countless threads on this issue, but am still confused
I have measured resistance at the ECU plug and found the OSR sensor (or wiring) to be at fault. I have located the OSR sensor connector block and measured the resistance there. Open circuit, indicating sensor or wiring fault.
Before changing the sensor, I want to know that this is the only fault. So I ( as recommended in another thread), put a resistance across the connector (1100 Ohms). It now measures 1140Ohms at the ECU plug. In theory, this should fool the ECU into thinking there is a working sensor and put the light out. But it doesn't.
I have also read that when you turn the ignition on, the ECU warning light will go on and off a couple of times as it tests the circuit. It doesn't. I have checked the fuses relating to ABS function and they both check out OK.
Are there any other checks I can do? Will a Lexia test be of help? Or should I just change the sensor anyway and see what happens? I don't want to keep throwing money at it and finding it still isn't fixed.
Car is a 1999 (T reg, S2) Xantia 1.9TD LX Estate.
Any thoughts, ideas, help, much appreciated.
