Laguna 2.2 DCI Starting Problem
This is the Forum for all your Renault Technical Questions, Problems or Advice.
Badge 714
Unread post by Badge 714 »
Good morning all.
I have a 54 plate Laguna 2.2 DCI and it has stopped starting! I can bump start it, and the battery is fully charged (6 month old Bosch Silver brand). When I put the card in the reader I get the usual click and the lights on the dash light up as usual. When I press the start button the glow plug light comes on and extinguishes as usual then a very faint click (relay energising?) then nothing and then the key card gets released. STOP and brake lights are illuminated. I have tested for loose connections on the battery posts and also on the starter itself.
Can anyone suggest a way of testing the starter motor in situ? Can I just short the solenoid out or will this cause more problems? Is there a fuse to the starter motor or is it the inline protector on the battery lead? How can I tell if it is the relay and which one is it?
Sorry for all the questions. Thanks for any help. Second car down in 48 hours. :-(
Lighty
x 35
Re: Laguna 2.2 DCI Starting Problem
Unread post by Lighty »
Not sure your issue is a starter problem, cant see why this would cause the ignition to turn off.
Reckon you need someone with a clip diagnostic tool.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
lexi
x 134
Unread post by lexi »
Could be the card reader? I don't know if you can hot wire the starter on the engine but you could take it off for testing.
Could be lots of things before the starter. Don't bump start the car if you have a CAT. Have you tried the other card?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
R9UKE
x 3
Unread post by R9UKE »
What is the little red immobiliser light doing throughout all of this?
French is best.
Badge 714
lexi wrote:Could be the card reader? I don't know if you can hot wire the starter on the engine but you could take it off for testing.
Yes, both cards. I was wondering if it was a synchronisation issue with the card and immobiliser but it does it with both cards. If kit was the immobiliser it wouldn't bump start would it? Take your point about bump starting and the CAT well reminded. Only did the once to try and eliminate the immobiliser.
Badge 714
R9UKE wrote:What is the little red immobiliser light doing throughout all of this?
Its on when the card is first inserted and the rest of the dash lights come on then it goes out, press start, nothing, then 5 or so seconds later the STOP, the battery and the hand brake warning lights come. Take the card out and the immobiliser light starts blinking.
R9UKE
x 3
Ah, you can rule out a key card, reader and immobiliser issue then as that's what the light should do.
My Vel Satis did this once and it was actually down to the battery. It wouldn't even jump start as the battery was that knackered, despite being absolutely fine up to that point. I would definitely try another one if you have access to one without paying for it.
French is best.
Badge 714
R9UKE wrote:Ah, you can rule out a key card, reader and immobiliser issue then as that's what the light should do.
I'll try another battery and also take the one that's in it, out and charge it aswell. See If I get anywhere with that before pulling the starter out.
Badge 714
Well the battery has been on charge for 24hrs. Its been tested at the local auto spares shop with a Gunson battery tester which said it was Good as rated at EN750.
Trying to get the starter out now but the bottom turbo to IC pipe seems to stick after travelling a couple of cms. Does anyone know what sort of pipe comes out of the bottom of the turbo, is there some sort of flange on it? Is it feasible to get the starter out without removing the turbo > IC pipe as per Haynes manual?
Badge 714
The starter is out and tested by the local Auto-Tech shop. It seems OK without load on it. What else is there between the card reader and the starter? Are there any relays or fuses in the starting circuit? I'm baffled.
R9UKE
x 3
Check the fuse marked "COUPE CONSO", the one marked "ALIM UCH" and the one marked "MEMO INJECT". Had a baffling starting problem with a Scénic the other day, and these were the culprits.
French is best.
Badge 714
R9UKE wrote:Check the fuse marked "COUPE CONSO", the one marked "ALIM UCH" and the one marked "MEMO INJECT". Had a baffling starting problem with a Scénic the other day, and these were the culprits.
Cheers for that, I'll give that a try tomorrow when I've got the starter back in :-( Where are they located? In the engine bay fuse box or in the cabin fuse box? I know you said a Scenic but I imagine they're probable in the same box.
R9UKE
x 3
You must be well frustrated by now!
They were all in the cabin fuse box of the Scenic, but seeing as the Laguna has a much more sophisticated system, some of them could be in the bonnet one.
French is best.
Badge 714
Well it's all back together, copper grease on all the terminals, and some lithium grease on the starter shaft and cog. And it started first time :? I suspect that the positive lead from the battery to the fuse box in the engine bay may have become slightly corroded which would mean the solenoid didn't activate. Still all done. I found a PDF detailing fuse and relay location and use on the internet. I can't credit the original source because I can't remember it sorry.Can anyone suggest a way of uploading it. The forum doesn't allow PDF extensions or TXT.
Now just need to work out why the drivers door window only drops and rises about an inch at a time.
sheriffdude
Unread post by sheriffdude »
thats a easy 1 wish my starter was as easy foir your windows you probably no this by now but this may help some 1 else just hold up all window button for like 20 seconds not sure on the time but if not try for longer every time you disconnect the battery you have to reset the windows ..my car as we speak is at ness motors Renault inverness there giving it a free diagnostic well i say free ...i was getting the back brakes fitted for 60 pounds not a bad price from them ..bought the part on line for 84 pounds not the 155..they wanted ..got the phone call both bolts on the calipers broken we need to replace them as the rotten ..price 90 pounds each ..ok so go ahead now my math was 60+90+90 as i had beed told it was 50 for brakes pluss vat...was 60 ..so how much 348..not 230 ...no we charged you 55 pounds to fit the calipers 38 pounds to fit the brakes ...58 pounds vat what a rip off..i asked dont you take off the calipers to change the brakes .no answers .then not happy drive car off abs warning light still on goes back and was told what do you want us to do about that ..after walking out manger followed me do you have a problem ..yes what do you think . explain all so now i have free diagnostic ..only thing is car will not start to get there so have to bump it park at Renault it stops and starts 5 times then stops lol hand them the key ...now do you think they will find the problem rant over ... [-o< :evil: will let you no when i do ...and after this i only have to fix both boot struts defuser pulley .. whistle noise for clutch both front windows ..pluss mile omater stopped at 68000 miles :-D
