upper column bearing - xant
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Chaps, has anyone replaced this (I am assuming there is one?)
Mine wheel has a percetable up down movement these days.. about 1mm I guess
John
DickieG
Monaco's youngest playboy
x 33
Re: upper column bearing - xant
Unread post by DickieG »
You'll be pleased to hear that the bush is not sold separately but comes a part of the whole column, a bargain @ £208.85 :shock:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
jgra1
(Donor 2021)
x 36
:shock:
thanks DG, that is the best news I could hope for today
:-D
DickieG
x 33
jgra1 wrote::shock:
:-D
That doesn't bode well :(
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
jgra1
(Donor 2021)
x 36
lol..
I will leave it and see what the MOT says I think.. The upper slip ring is not in the car, wonder if that will help settle things down a bit...
x 94
Unread post by citronut »
if its like a BX one the lower bush drops out of the columb tube,
the fix for that is push the bush back in then tap the bottom edge of the tube over in 2 or 3 place's to stop it droping back out,
regards malcolm
jgra1
(Donor 2021)
x 36
would the lower bush have any bearing on upper column movement Mal?
x 94
i belive it can do John
if the lower bush has droped out of place the columb shaft will wagle at the bottom which can give the impresion the top is moveing about,
regards malcolm
lexi
x 133
Unread post by lexi »
This wearing of the bush could be caused by being stuck in traffic jams and gripping the wheel while rocking it violently in frustration :shock:
Is there any way of fitting a generic bush?..........that sounded like some kind of gardening question :-D
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
