C8 faults and (hopefully) fixes
Stekelly
Unread post by Stekelly »
Right I've started having a mess with the lexia on the C8 and figured one thread for the faults would be best :-).
I'll start at the begining. I have an airbag fault which is coming up as passenger level 1 airbag igniter open circuit . From taking it as read I'm guessing its either disconnected or a broken wire maybe? Could it be that simple? When i turn the key its now coming up on the cars display that the airbag is being deactivated and bringing up the baby in the car seat light above the airbag light which I assume it does if you deactivated it with the key. Wasn't doing that before.
I'm on my phone at the minute jt ill add issues later as well as lexia screen shots if needed.
Stekelly
Re: C8 faults and (hopefully) fixes
The passenger airbag described light doesn't seem to be coming on anymore. Took the car for a drive. I might have just confused it for a bit by turning it on and off with the key to check it.
The antipollution issue from the other thread seems to have changed. It's no longer showing up every time I start the car. I took it for a drive and in the 3 times I had to start the car it flicked up once for a second but went. Ihave screenshots o the laptop from the fap section on the lexia and it said something like fuel filler cap to earth issue.
Stekelly
Still no closer to finding a solution (admittedly I havnt been back at the car yet though) so any help much appreciated.
