Does this height corrector overhaul tutorial apply to C5?
Jabo
Unread post by Jabo »
http://www.eastment.net/hcrefurb/index.htm" onclick="window.open(this.href);return false;
Does this also apply to the C5 mk1?
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
Jabo
Re: Does this height corrector overhaul tutorial apply to C5
I don't know if I need it for sure yet but I've done a few sessions of Citaerobics and the ride is still a bit harsh. I watched the reflections of the lights yesterday when driving and it was like the car was rocking.
And the suspension sits lower at the rear with the engine off. It has a tool box and 2 subwoofers in the boot but I didn't think that was enough to drop it...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
C5 models have a potentiometer arrangement for height correction. No hydraulics involved...
x 5672
Jabo wrote:I don't know if I need it for sure yet but I've done a few sessions of Citaerobics and the ride is still a bit harsh. I watched the reflections of the lights yesterday when driving and it was like the car was rocking.
Mine sometimes feels a bit harsh, especially in comparison to previous Citroens (nothing like the GS).
Other times it seems fine though still inferior to previous models.
Mine is generally loaded up with crap in the luggage space and never sinks more than half an inch overnight and can be rear, front both or neither, completely random.
I do find that it rides better when heavily loaded and for a while after being seriously overloaded.
mirafioriman
Unread post by mirafioriman »
Great article for Xantia owners there. Might have a go at overhauling my height correctors ;)
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Jabo
Engine off/engine running mine still sits lower at the rear in the normal position. When it's dropped or in either of the raised positions it seems to be ok front to rear.
Just doesn't seem normal :-/
cachaciero
x 9
Unread post by cachaciero »
Jabo wrote:http://www.eastment.net/hcrefurb/index.htm
In a word no! the C5 uses a completely different system, the height sensor is a potentiometer, the correction is done in the BHI
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Jabo
cachaciero
Boo :( will need to get hold of a Lexia at some point then.
x 5672
If there are problems maintaining level ride on a C5 it is usually the potentiometer has worn or dirty tracks.
Or has suffered mechanical damage (impact from flying debris from the road).
It's a cheap and simple fix to replace. A new potentiometer is IIRC around £30 and takes about five minutes to change.
There is some allowance for mechanical adjustment but fine tuning requires a Lexia.
