Airbag light & MOT
corsehf
Airbag light & MOT
Unread post by corsehf »
Hi, My MOT tester tells me that the Airbag Light is now part of the test and typically!, I have an Airbag Light issue and have had it now for the last 6 months but not had time to look at it except for a quick butchers under the passenger footwell to check the plugs (thanks to the info on this forum!) but could not see any problem. I did pull the plugs apart and wd40'd the connectors but to no avail. I will check for continuity next time before i solder them up.
Anything else i need to check as well just in case this does not work??
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
x 1043
Re: Airbag light & MOT
Unread post by wheeler »
corsehf wrote: I will check for continuity next time before i solder them up.
NEVER PUT A MULTIMETER SET TO OHMS ONTO AIRBAG WIRING WITH ANY PYROTECHNIC DEVICES OR ECU's STILL CONNECTED TO IT
An ohmeter sends out a small current to do an ohms check, this can be enough to detonate an airbag unexpectedly.
x 1238
Unread post by Peter.N. »
I believe this new airbag light rule only starts in April. My 406 has just passed with the airbag light on.
corsehf
Peter.N. wrote:I believe this new airbag light rule only starts in April. My 406 has just passed with the airbag light on.
Not sure, i was told January.
Andy
1994 ZX TD Volcane
woodywoodpecker
Unread post by woodywoodpecker »
corsehf wrote:Hi, My MOT tester tells me that the Airbag Light is now part of the test and typically!, I have an Airbag Light issue and have had it now for the last 6 months but not had time to look at it except for a quick butchers under the passenger footwell to check the plugs (thanks to the info on this forum!) but could not see any problem. I did pull the plugs apart and wd40'd the connectors but to no avail. I will check for continuity next time before i solder them up.
Hi Andy,
Soldered mine up last month and it as sorted the airbag light, Bit of a pig to hold the wires together and solder them with one pair of hands though...lol.
I think if i was doing it again i would buy some of them electric block connectors they come in a strip that you tighten up the screws to secure the wires together would of been alot easier.
x 1432
New rules came in on Jan 1, but there is a 3 month amnesty on the new items, so you should get an advisory, and note that it will fail next year.
If fixing the wires under the seat does not put the light out, then diagnostic session reuquired to see where the fault lies.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
it seems a bit of a lottery this..
my (new) mot tester last week, who seemed a perfectly decent chap, said SOME new things are Jan and some April.. I cant remember what he said about the airbag light though ;)
edit
having said that, I am fed up with the in car disco-effect.. and passengers saying, is that safe, driving with that on? (it may not be if it goes off in their face 8-) ) :-D
but... I would like the car to get back to being as good as it can really.. a losing battle :twisted:
I have about 2 weekends to pre-mot mine, very soon..
x 1238
Mines been flashing since I bought the car over a year and 11,000 miles ago, Iv'e got used to it now :-D
corsehf
Peter.N. wrote:Mines been flashing since I bought the car over a year and 11,000 miles ago, Iv'e got used to it now :-D
Need to get it sorted now!!
Ok, i have now removed the plugs and the are now wired direct and the result is that the airbag light (and bong!) now comes on after about a minute??
I have only done 2 plugs, a brown one and a blue one after reading another thread on here about it. Should i be doing the other two plugs??
It seems i have changed something but not fully. Anything else i can look at??
Andy
1994 ZX TD Volcane
chrissa
Unread post by chrissa »
Hi Corsehf, had same Airbag issue with my wife's Xantia 1.8 Forte Y reg just 2 weeks before Mot last year
searched forum and one member said try using switch cleaner in the key switch that turns it on/off
I too had checked plug/sockets etc but once switch cleaner used it's been fixed ever since.
Cheers, Chrisso
handyman
Unread post by handyman »
It is advisable NEVER to use WD40 or any of those other crap maintenance sprays on any electrical connections.
As the spray contains silicates that deposit themselves on any contact surface, all you have done is added a nice layer of insulation between the two points you are tryng to improve electrically. The only spray you should use anywhere near any electrical items is switch cleaner as this is does not contain chemicals that will set up a chemical insulation barrier.
Simple really.
H
x 1238
As a retired electronics engineer of 50 years+ my experience has been that WD40 very often works better than Servisol, certainly on volume controls.
spider
x 77
Unread post by spider »
wheeler wrote: NEVER PUT A MULTIMETER SET TO OHMS ONTO AIRBAG WIRING WITH ANY PYROTECHNIC DEVICES OR ECU's STILL CONNECTED TO IT
This is true, although the risk is not great it can (and does) happen.
You can check the wiring by all means but you **must** disconnect it at both ends, ie no airbag / seatbelt tensioner and no ECU, so all you are checking is a piece on disconnected wiring. If in doubt, don't check it.
Actually does a Lexia not show a resistance reading for you ? :?:
Andy.
corsehf
As my car DID get through the MOT with an advisory for the 'Airbag light', I've not had chance to look at this now for a while but there must be a fair few people out there now being caught out with this new issue.
In reply to Chrissa, i used to have a Xantia and if i remember, a quick spray of WD40 down the ignition key barrel used to fix many issues - on mine, it cured the blowers for the heating & demist.
Andy
1994 ZX TD Volcane
lurchy666
Unread post by lurchy666 »
if u have the keyswitch next to handbrake, get it out tip it upside down and move the key about in it to get all the dust etc out of it, if that dont work take the top of the switch off carefully as there is a spring in there and make sure the key part is connecting to the switch in the bottom, sometimes a good blast of switch cleaner will solve it, sometimes just gettin your key in it and moving it around a load of times does the trick,
if that dont work a lexia sesion will be needed to say whats actually wrong with it,
c5 2.2 auto hdi estate 52 reg
