Merged Lexia & Diagbox threads
allanmc
Re: Lexia group discount through moderator?
Unread post by allanmc »
There is a permanent fault its related to the ongoing problem of the battery draining which I am still waiting for a guy with a Lexia getting back to me he is downloading a wireing diagram so at this stage I will wait for him before I try anything myself
allam
Xantia 2.0i SX Auto, 1999
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
What model of car are you dealing with?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
Unread post by citronut »
is there access to actual values to what you should see for each car interigated on the DIS-LEXI-PLANNET,
if not were can i find them
regards malcolm
DickieG
x 33
citronut wrote:is there access to actual values to what you should see for each car interigated on the DIS-LEXI-PLANNET,
Look to the bottom of the screen and you will see a few buttons with symbols such as 'help' and '?' go into one of those menu's and you will find further info, how much info is there depends upon each particular car and the software version installed on it, the general rule is that the later the car the more info is available as to what range/value the perameters should be within.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
jmd
Unread post by jmd »
Had trouble myself installing the Lexia software, but in combination with the advice given here which I found very helpful this websit is also worth a visit - http://esobd2.wordpress.com/2011/07/15/ ... ol-pp2000/" onclick="window.open(this.href);return false;
allanmc
Richard, I dont know if it was my car that you were asking about, its a Xantia 2ltr. HDI 110 BHP year 2000
allan
DickieG
x 33
allanmc wrote:Richard, I dont know if it was my car that you were asking about, its a Xantia 2ltr. HDI 110 BHP year 2000
allan
Yes I was, is a fault recorded related to the battery draining?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
allanmc
Richard, the fault points to an injection fault with the injection relay in place the battery drain is over an amp and when the relay is removed the reading goes down to just enough for the clock and radioon standby I bought a new relay but it didnt help so looks like whatever comes after the relay is at fault I am waiting for the guy to download a wireing diagram from Service Citroen so I will have to wait for him to get back to me
allan
red_dwarfers
x 58
Unread post by red_dwarfers »
allanmc wrote:Jim, thanks for your help my son evenualy downloaded the lexia 3 onto my PC as I said I dont have a laptop yet,so today carried the PC, Monitor, and keyboard into the garage and conected it up to the series 2 Xantia tried to access the AC ECU but as others have said it didnt work is there any way round this, I must say I dont want to take all this lot out to the car again, I will get a laptop asap not sure when
allan
I've had the climate control ECU not being picked up on the Xant two or three times. After a very quick bit of experimenting I found that if I come out of climate control, go into the ABS ECU then go back to the climate control one I can get it. I've got a funny feeling this could just be coincidence or one of those things with mine but theres no harm in sharing it just in case!
Kev
'19 C4 Cactus 130 Flair
x 8422
red_dwarfers wrote: I've had the climate control ECU not being picked up on the Xant two or three times. After a very quick bit of experimenting I found that if I come out of climate control, go into the ABS ECU then go back to the climate control one I can get it. I've got a funny feeling this could just be coincidence or one of those things with mine but theres no harm in sharing it just in case!
Thanks Kev :-D I'll give that a go tomorrow. I've got into my New V6 climate once but never on another MK2. I got into Old V6s climate (MK1) no problem at all...
DickieG
x 33
I have two orders for Lexia's pending at the moment, the sellers stock is low at the moment but he apparently has another batch due in about three weeks time so if anyone else would like to place an order to build up a bulk purchase (cheaper price) please let me know.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8422
Tried it Kev, both my Activa and Rattiva and no go... I popped the ELIT on and got into both no worries at all but the odd thing was that the ELIT, despite having selected Xantia claimed the car was a Xsara and that tghe climate ECU was a Valeo.
Tried to fool the Lexia3 into thinking it was a Xsara for a test but no go...
Odd that the Lexia3 can get into some climate ECUs and not others...
red_dwarfers
x 58
Oh well, it was worth a try!
Kev
jmd
HAving problems installing Lexia Software. (PP2000 installed O.k) Gets to the stage of confirming what language to use & then says. "Install/Update" when I click on this it says "Please install Proxia Recovery CD before installing this version". I uninstalled already having had the same problems as Paulhelliwell2. It is while attempting to reinstall I get the above messages. Any help would be appreciated.
x 8422
jmd wrote:HAving problems installing Lexia Software. (PP2000 installed O.k) Gets to the stage of confirming what language to use & then says. "Install/Update" when I click on this it says "Please install Proxia Recovery CD before installing this version". I uninstalled already having had the same problems as Paulhelliwell2. It is while attempting to reinstall I get the above messages. Any help would be appreciated.
You need to create an empty file in the root of drive C:\ called version.txt and all will then be fine.
Use Notepad to create the file. Just open Notepad and immediately save as version in C:\ and all will be fine.
Look at C:\ and check the file is saved as version.txt and not as version.txt.txt which can happen if you save it as version.txt and you have file extensions for known file types hidden; the windows default.
