Xantia Lower Steering Column Shroud Removal (R reg)
citroenxm
Fallen Hero
x 70
Re: Xantia Lower Steering Column Shroud Removal (R reg)
Unread post by citroenxm »
CitroJim wrote:
citroenxm wrote: crank sensor, a common PSA item fitted to many,
On the 110 HDi it's an absolute ***** to replace :twisted: It's nearly as inaccessible as on the V6...
RUBBISH Jim :) 8-)
Its not hard at all to remove, its only hard to get the 10mm nut back in!! :-D :-D :-D
Admittedly it is hidden under the massive water housing jacket!!
A very sad...
1994 XM 2.1 d auto
x 8457
RUBBISH Jim :) 8-)
Absolutely right Paul :-D Easy to remove, not so easy to replace. When we did Chris's clutch I left that job to him :lol: :lol: Me not grow old without growing a little wise :wink: :)
gadgetgricey
Unread post by gadgetgricey »
Once again getting ahead of myself, but how much would a garage charge for a cam belt water pump and crank pully change.
Just trying to factor in prices etc.....
Cheers
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
citroenxm
Fallen Hero
x 70
on a hdi dave?? its not much harder then a td except the belt tensioning.. id recomend getting the belt KIT as hdi pullys are stupid plastic ones..
i do cam belts water pumps as a job for about 100 plus parts.. crank pully is a nautral change as it has to come off anyway..
you would have to go and see yur indys for prices but a reckon about 250 to 300 off the top of my head.. that should include freah new anti freeze though...
A very sad...
1994 XM 2.1 d auto
