Merged Lexia & Diagbox threads
paulhelliwell2
Re: Lexia group discount through moderator?
yes i created the folder its all installed but its the activation of it that the error comes up when you generate the key and enter it it comes up with the error
- x 8131
That's odd. It normally just comes up with Activation failed if the generated key is incorrect.
One point that is required on the keygen I've used is that the version must be entered as LEXIA-345 and not the exact version as shown in the [INFO ]section of version.txt.
You have the correct numbers recovered from the Lexia Office Activation screen entered in the right fields in the keygen?
What does the key generated by the keygen look like? It should look a bit like a Windows XP licence key.
say something like KG3XX-GFD4E-CCV8Y and so on.
Are you pasting int the activation screen or manually typing it? I've noticed with my keygen that the key can disappear and go blank when trying to copy it. Also, make sure when entering the key by pasting it that you're not accidentally pasting in a leading or trailing space.
paulhelliwell2
yes this is the last code A511-12F4-B6EC-F5B3-60C6-56FA-BA07-10B6 but it came up
the activation code is not valid(error code 11).
- x 8131
That's excellent Paul... Just a straightforward activation failure.
Can you go through the Activation procedure again and write down exactly what comes up on the Lexia Office Activation screen and what fields in the keygen you're putting the data into. The field names on the keygen don't exactly match what appears on the Lexia Activation Screen and there's scope for confusion there. Also, don't worry if the computer ID number comes up as a zero. It's valid. What customer ID are you using. Something like CH001? It should be on the activation screen.
The activation key must be generated with the Lexia Office still open and connected to the pod; the pod must be alive too (i.e. geen light glowing). Activation will fail if you exit Lexia Office, generate a key and then restart Lexia Office to enter it...
We'll get there
We'll get there
paulhelliwell2
application management
activation/deactivation confirm
activation confirm
configuration of proxys ? f9
in order to be able to use the applications,you have to activate them.
you can activate the software packages automatically via the internet using the f2 key.
it is also possible to perform an activation manually via the internet. or even through "technical assistance" via button f3. f3 used
you will activate the applications.
please enter your RRDI code. CH0001
then please confirm to start activation.
CH0001
confirmation of your RRDI code:
CH0001 confirm
this screen lets you activate the applications manually.
there are two different ways in which to do this:
1. by connecting to the internet address
https://www.wrs-actia.com/psa/clientlogin" onclick="window.open(this.href);return false;.
2 by calling technical assistanceACTIA.
in both cases, you will be asked for the following information:
your RRDI code,check whether the following code is correct: CH0001
the number of the version of your software packages: LEXIA-346.22
the identifier of your pc: 1959564647
the server request code: 2341
from this information, you will be given an activation code.
please enter this code in the box below and then confirm to complease the activation:
open key gen
your customer no CH0001
identifier of your pc 1959564647
number of the version LEXIA-345
server request code 2341
get code
D928-4959-8E2A-41DF-5FA6-7C4C-350E-4D38
confirm
the activation code is not valid (Error code 11).
activation confirm
CH0001
CH0001 confirm
open key gen
get code
confirm
- x 8131
Paul, you appear to have V46 there..
In the keygen try entering LEXIA-346 as the number of the version and trying again...
If that fails Then I suggest you acquire a copy of the V45 software we know works
paulhelliwell2
you were spot on CitroJim thank you now activated
can i just what is a PRO No ?
- x 8131
Excellent news Paulpaulhelliwell2 wrote:you were spot on CitroJim thank you now activated
Is that the RPO Number? That's the build code of the car and gives the date of manufacture in a coded format. It's normally found in later cars on a white label in the door shut below the tyre pressure information and along with the paint code. The number often ends in CJ to identify the factory the car was built in.
earlier cars often had the RPO number stenciled in yellow paint under the bonnet somewhere. On Xantias for instance it was stencilled on the driver's side bulkhead just behind the strut top. The RPO number moved to the white label in the door around 1999.
paulhelliwell2
ok thank you
garrydog
Hi My Lexia 3 came today many thanks to DickieG for sorting it all out for us.I have a problem with my old laptop Dell c640 it wont read the dvd disc that the software comes on,the drive is a CD RW don't think it will read dvd .Can i install Lexia in any other way or will i have to get a new drive.
Thanks.
Thanks.
2004 C5 VTR 2.0L HDI hatchback.
The Birdman
Lexia 345
http://www.rapidshare.com/files/4147202 ... part01.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147205 ... part02.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147209 ... part03.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147213 ... part04.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147217 ... part05.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147222 ... part06.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147226 ... part07.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147229 ... part08.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147233 ... part09.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147236 ... part10.rar" onclick="window.open(this.href);return false;
http://www.rapidshare.com/files/4147240 ... part11.rar" onclick="window.open(this.href);return false;
Password - Patrian Automotive Industries
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
The Birdman
Citroen Lexia 3 V45 to V46.6 online update
http://rapidshare.com/files/414119378/U ... 8.exe.html" onclick="window.open(this.href);return false;
The Birdman
Or you can go from lexia v45 to v47.18
https://rs956l33.rapidshare.com/#!downl ... 772D61|0|0" onclick="window.open(this.href);return false;
paulhelliwell2
quick question how easy is to re-programe the keys so i can do the remotes?
thanks in advance
thanks in advance
- x 8131
Even easier than RapidShare... If yo have any PC that can read the DVD then copy the contents from the DVD to a USB stick and install using that.
Birdman, what's the advantages and benefits of upgrading from V45 to V46 or V47?
I can only say for a Xantia but it's dead simple so long as you have the transponder code. The Lexia 'holds your hand' right through the processpaulhelliwell2 wrote:quick question how easy is to re-programe the keys so i can do the remotes?
thanks in advance
