Merged Lexia & Diagbox threads
xmexclusive
Re: Lexia group discount through moderator?
Unread post by xmexclusive »
Yes a single disk with an autoload programme.
Mine failed to auto load though and it took me a lot of work to get it loaded manually.
Needed to dissable and remove a number of existing laptop programmes including antivirus.
Then Lexia3 insisted on ringing home.
Laptop was not enabled on my home network so it found itself an unprotected local wireless net connection.
It then proceeded to contact the Citroen website to upgrade the version.
I pulled the plug as I wanted to stick with the current version for now.
Loaded version works fine on an XM Mk2.
John
Xmexclusive
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
citronut wrote:mine has just turned up,
does the DIS-LEXIA and PLANET software all come on the one disc,
as mine only came with one disc with LEXIA writen on it
That's how the first three arrived Malcolm, all on one disc.
Make sure you turn off Wi-Fi when using Lexia to avoid it trying to contact the Citroen website.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I do have an old lappy...
the battery is not much use.. but
x 94
Unread post by citronut »
pm sent John
regards malcolm
jgra1
(Donor 2021)
x 36
replied Mal..
it should be ideal for diag work.. I would clean it off and reinstall xp and keep it free of rubbish..
Will run fine from a ciggy inverter for on the move diagnostics i would think..
no idea what its worth really.. ;)
x 8336
regards malcolm
Yes, it does Malcolm. If you have problems installing or activating it (the instructions are not 100% obvious) give me a call and I can talk you through it...
Lexia and PP2000 happily co-habit...
jmd
Unread post by jmd »
Will the Lexia software load with Windows 98 ?, or is Windowns XP the basic requirement. I have an old laptop with Windows 98 (Battery useless -like all old laptops) only 64 Mb Memory and a Celron 500 Mhz processor. The processor should be O.K to drive Windows XP & Diagnostic software, with the laptop doing no other function, but will probably have to upgrade the memory from the exixting 64 Mb to 512.
Wondering if anybody is in the same position with old similar type Laptops or have any views.
x 8336
Given that '98 written in the old 9x codebase and XP is based on NT in all probability the Lexia won't run on '98. Even in the Lexia2 it runs under XP.
Hardware-wise the Lexia needs very little in the way of computer grunt so I reckon it's best to bin '98 and install a very basic XP on the laptop. XP is very compatible with lots of hardware and as the laptop is now quite old in laptop terms you may not even need any extra drivers for it.
You will need a screen resolution of at least 800x600 to run Lexia.
paulhelliwell2
Unread post by paulhelliwell2 »
need help installing software as i keep getting error code 11
DickieG
x 38
paulhelliwell2 wrote:need help installing software as i keep getting error code 11
Where did you source the Lexia/software from, is it from the same seller as at the start of the thread? The reason I ask is that there are quite a few variations of the software.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8336
Putting my professional hat on for a minute... Saying you get Error Code 11 is a bit like me saying I have 11%. Sadly it's meaningless by and large without context.
So, when and where do you see Error 11? What part of the install and is there any other information apart from Error Code 11? What is the title of the window it pops up in. Whereabouts in the install procedure is it generated and is it generated by Lexia or by Windows?
Give as much detail as possible and we'll be better able to help.
I've reinstalled mine on numerous times and never a problem - using the software supplied.
paulhelliwell2
no i bought it from ebay
[INFO]
VSOFT=345.13
VSOFTVISU=CD-ROM 45 (345.13)
MASTER=CD45
x 8336
paulhelliwell2 wrote:no i bought it from ebay
From the same seller or from another?
Where did you get the [INFO] data from?
paulhelliwell2
lexia folder exe folder version.txt
x 8336
paulhelliwell2 wrote:lexia folder exe folder version.txt
OK. did the instructions tell you to create an empty version.txt in the root of drive C:\. This seems very critical in V45.
I confirm that's the same version as I've installed.
So where and under what circumstances does this Error Code 11 appear?
