saxo 1.1 srarting problem
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
hi..
got a request from a customer.. car is a T plate saxo 1.1.. they are having starting problems when cold.. but appears fine when warm.. is there anything obvious on the tu i could look at. or just run a lexia session and see what sensors are dooing what...
thanks
A very sad...
1994 XM 2.1 d auto
x 8457
Re: saxo 1.1 srarting problem
Coolant Temperature Sensor is the first port of call Paul... Mr. Lexia will tell you how it's looking.
Plugs are worth a look at as they're hard to get at and may well have been ignored for years.
Also, check for manifold air leaks, especially on the breather pipes. They get a bit delicate as the years roll by. I once knew one hole all its pistons because of a broken breather spigot. It made the engine run very weak.
