Hi,
I need to order an aux/alternator/fan belt and the timing belt for my car.
I need to know the exact engine type/number so I can get the right ones.
I think it should start XUD9...
On my registration documents there is an engine number but there is nothing starting with XUD9..
There are two plates riveted on the engine block, one small with printed letters, the other one larger which has been engraved.
After a lot of scraping I can only read the smaller of the two plates, the larger one will probably need removing and degreasing to read, it might just be the serial number tho?
The smaller of the two plates has 'D8B' printed on it.
I think this should translate to another number like (XUD9TEF/L, XUD9TF/W2, XUD9BTF/L3...)
Anyone know how I can find this out?
Thanks frustratedly, Romie
Engine type? D8B on riveted plate?
romie
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
romie
Re: Engine type? D8B on riveted plate?
Citroen Xantia 1.9TD Estate 1996
Bosch IP
(may or may not have aircon. Seems to as it has a bottle with a sight glass like the dryers found on other air con systems. But there is no obvious aircon pump or air con switches in the cockpit :/ )
Bosch IP
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
I've just rang Unipart and they reckon from the number D8B it's an XUD9TF.
Is this correct?
Sorry for the rant but:
How'd they know that?
Why didn't Citroen just put XUD9TF on the plate instead of D8B?... or just use D8B for reference instead??
And now there are two choices for the axillary belt depending on if I've got aircon or not.
Sorry if this sounds silly but how can I clear this up?
Having spend an afternoon fighting to remove the front bumper to change a rad fan, (I mean could you have put the bolts in a more difficult place to get to!) I noticed I have three rads? Oil, Water. . and errmmm?
Cheers fellows
. . (oh and no, I don't get cold air from the vents when I set it to cold. And the engine has never laboured - like trying to kick-in an aircon compresser)
Is this correct?
Cheers fellows
Yamaha R1 1999 26k
Yamaha R1 1999 26k
Most parts suppliers can now identify your car and all its spec from the VIN (chassis) number.
romie
hmm, so Citroen said it a XUD9TE
They also said no it doesn't have aircon. . . . . oh. Yes it does.
So it would make sense that it does, although it's never worked and there is no buttons or wording in the car that suggests aircon.
Just a slidey thing that goes from blue to red.
And a fan strength adjustment thing that goes from Auto - fan symbol - max
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
Hey Gibbo2286, I'm a thrifty guy after ebay jobbies so need to match engine types as they prob won't know :/
Cheers tho
Cheers tho
Yamaha R1 1999 26k
Yamaha R1 1999 26k
The Birdman
Do you want to send me your vin number and i`ll see what info i can get .
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
romie
Hi, Birdman
That would be fantastic!!
I'll pm you vin and the engine number from the reg docs.
Please let me know if any further info would be useful.
Many thanks
Many thanks
Yamaha R1 1999 26k
Yamaha R1 1999 26k
VertVega
- x 13
From your signature (Citroën Xantia 1.9TD Estate 1996) specs should be like:
1.9 TD X,SX (66kW) TDI XUD9TFL(D8B/1) 9-1995 1-1998
(here's source of information: http://xantiaclub.net/motortypes/" onclick="window.open(this.href);return false;)
The Birdman
Vehicle characteristics
Vehicle family XANTIA
AS RPO No 07105 U7 2 0037
Warranty Start Date 01/01/1990
Engine serial number 10 CUJ3 6008592
Gearbox serial number 20 CH97 7574450
OPB D00D
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XANTIA
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL LEVEL 1
ENGINE TURBO DIESEL XUD9TE
TRANSMISSION BVM5
INTERIOR TRIM TYPE VOGUE VELVET "BR"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BE3
OTHER BADGE TURBO D
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE XANTIA BADGE
TRIM LEVEL LEVEL 1
STEERING POWER STEERING
Fuel supply-Engine
FUEL SUPPLY TURBO-INJECTION EXCHANGER
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 19-5 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 15 X 64
WHEEL STYLE STEEL WHEEL
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 185X65X15 T TYRES
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
Suspension-Steering-Brakes
ABS W/O ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 23
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23 - 14,6
TRACTION CONTROL WITHOUT ANTISLIPPING
HYDRAULIC STOP WITH HYDRAULIC STOP
HYDRAULIC PUMP PRESS PUMP 6+2 + NON-SINKING
REAR SUSPENSION SPHERE IMPROVED RR SUSP SPHERE
ACTIVE ANTI-ROLL W/O ACTIVE ANTI-ROLL
FRONT SUSPENSION SPHERE DESMOPAN WITH TALC
MAIN ACCUMULATOR SPHERE TALC DESMOPAN ACCUMULATOR SPHERE
STEERING TRAVEL STEERING MECHANISM TRAVEL 74,3
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
Body fittings
HORNS HORN STANDARD
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
WHEEL EMBELLISHER (STYLE) BARCELONE STYLE 5 HOLES 15 INCHES
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT INDEXED REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING BULKHEAD + BONNET SOUND-PROOFING
LIGHT CLEAR GLASS
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BODY COLOUR GREY STRIP
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP NO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES 2 COLOURS EXT ACCESSORIES
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
Interior fittings
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
REAR HEAD RESTRAINT WITHOUT REAR HEADREST
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITH REAR ARMREST
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITH LUGGAGE COVER
REAR SEATBELT REAR RETRACT BELT + ABDOMINAL RETRACT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
RADIO EQUIPMENT FEED AERIAL RECEIVER FRNT SPEAK TWEETER
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
DASHBOARD EQUIPMENT FACIA PANEL WITHOUT WOOD
MISC. INT. LAMPS MAP READING LAMP
DOOR TRIM DOOR PANEL WITHOUT WOOD DECOR
TACHOMETER (SIGNAL CONNECTION) REV COUNTER FLYWHEEL
LOUDSPEAKER 4 LOUDSPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFING SOUND-PROOF 7KG/M2
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) W/O INSULATION (CURTAIN,SUN VIS SCR,SUN ROOF)
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT WITHOUT DRIVERS LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT W/O PASSENGER LUMBAR ADJUSTMNT
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM + PLIP
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
COURTESY MIRROR DRIV OCCULT+PASS W/O LIGHTING
OIL GAUGE OIL LEVEL WARNING INDICATOR
FITTING REAR HEAD RESTRAINT WITHOUT REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
PASSENGER AIRBAG NO PASSENGER AIRBAG
IGNITION CODE (OPERATION) STD CODED IGNITION
RADIO RECEIVER PERFORMANCE 1 RADIO
REFRIGERATION REGULAR AIR CONDITIONNING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
AIR CON./TEMPERATURE REGULATION WITH SIMPLE REGULATION AIRCON/TEMP
STORAGE (OTHERS) LOWER SETTING BOX FRONT DOOR
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
REAR CARPET DILOURS CARPET F330
LIGHTING TIMER ADJUSTABLE TIMER
EXTERIOR TEMPERATURE (SCALE) WITHOUT EXTERIOR TEMPERATURE GAUGE
SWITCH CODED IGNITION
WATER TEMP INDICATOR COOLANT GAUGE + LED + PREWARNING
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH + AIRBAG
Electrical
ALTERNATOR ALTERNATOR 80 AMP
HORNS HORN STANDARD
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
LIGHT CLEAR GLASS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITH REINFORCEMENT
SURFACE CONDITIONS GOOD TERRAIN
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE
POWER VARIATION (FISCAL RATING) W/O TREASURY RATING VARIATION
OPB D00D
General information
PRODUCT TYPE CAR
TRIM LEVEL LEVEL 1
TRANSMISSION BVM5
OTHER BADGE TURBO D
BADGE XANTIA BADGE
TRIM LEVEL LEVEL 1
Fuel supply-Engine
FUEL DIESEL FUEL
Gearbox-Driveshafts
TRANSMISSION BVM5
ABS W/O ABS BRAKES
Body fittings
HORNS HORN STANDARD
LIGHT CLEAR GLASS
SUN ROOF FIXED ROOF
Interior fittings
Electrical
HORNS HORN STANDARD
LIGHT CLEAR GLASS
Miscellaneous
romie
Aha, thanks very much Birdman! Wealth of information
I don't suppose you know what the characters mean do you? I mean when I search for these belts is shows a number of different variants with different characters after 'XUD9TE'.
XUD9TEF/L for example? Different options?
Or is it that it can only be that number somehow?
Amazing how tedious they can make this simple acquisition
Yamaha R1 1999 26k
Yamaha R1 1999 26k
Dommo
- x 20
In the 306 world a d8b is a good thing and a (fitted to later 306's) is a bad thing. There was a spate of conrod failures on 97 ish dhy engines, rumours were they had fitted n/a rods to a turbo engine, but there was also a mention of a blocked oil sprayer on one piston/rod.romie wrote:Aha, thanks very much Birdman! Wealth of information
Not sure if it's when they put cat's on but it's essentially the same engine, both xud9te iirc
