Top of the range xantias spotting
jacksun1987
Unread post by jacksun1987 »
Thought ill come up with another good game.
Spotting xantias with differnt intera nice spec
Hers a good one to start the ball rolling.
Looks well nice
http://www.autotrader.co.uk/classified/ ... ?logcode=p" onclick="window.open(this.href);return false;
x 8391
Re: Top of the range xantias spotting
I spot three top of the range Xantias every single day in my own driveway :-D
Chris570
x 36
Unread post by Chris570 »
no you don't, you only see 2
whereas i see 3 top of the range citroens ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
x 8391
Chris570 wrote:no you don't, you only see 2
True :lol: I have to drive or walk a short distance to see the third one...
Chris570 wrote:whereas i see 3 top of the range Citroëns ;)
Ahh but don't you park one of yours around the front of the house Chris?
Chris570
x 36
Nope all 3 are housed in the PSA area (to allow for SWMBO's 206)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8391
Chris570 wrote:Nope all 3 are housed in the PSA area (to allow for SWMBO's 206)
But a 206 is a PSA too :?
Chris570
x 36
i know hence why its called a PSA area as opposed to the Citroen section
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
jacksun1987
What sort of kit do you get o the early vxs modles. Compered to the later exculsive modles. Plus was they a modle up from the vsx. On the early ones.
I might be off to view a vsx 1.9td easte on a n reg
Chris570
x 36
you should get variable speed wipers (not auto) and climate control and Hydractive 2 suspension.
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
jacksun1987
What on the vsx ones?
What about the cd changer. I was sat in a sx ages ago. Andlookin at the book. There was a 6 disk cd chnger
jacksun1987
What does the hydroactive 2 suspension does. Is it anygood.
How do i tell if its working prpperly.
He said he will take my corsa in as well
Chris570
x 36
its the suspension that flicks from soft to hard dependent on what the sensors are seeing (i.e. are you driving quickly etc) its very good indeed. RE Changer, i think so, but i'm not 100% its standard fit on the VSX
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
jacksun1987
cool i hope i get it. Im going to cripple my self on the mony frount. But if i get it ill be sorted. Im a bit worried about driving a estate. Ive never driven 1 before. Surly they arnt that bad to park.
Northern_Mike
jacksun1987 wrote:cool i hope i get it. Im going to cripple my self on the mony frount. But if i get it ill be sorted. Im a bit worried about driving a estate. Ive never driven 1 before. Surly they arnt that bad to park.
I always found my Xantia and XM estate dead easy to park. Loads of visibility, and unlike a small car, when you turn the steering wheel - especially when reversing, things far away at the back end happen slowly, so it's easy to correct immediately.
Worst car I had for parking was also the smallest - Ford Puma. Poor steering lock, awful rear visibility. Brilliant in every other way though.
x 8391
Activa_Mike wrote: I always found my Xantia and XM estate dead easy to park. Loads of visibility, and unlike a small car, when you turn the steering wheel - especially when reversing, things far away at the back end happen slowly, so it's easy to correct immediately.
I'll go along with that :-D The Estate has much better rear visibility and accurate parking ability than the Xantia hatch...
