Hi,
The drivers armrest is misbehaving in that is no longer goes down low enough. Does anyone know how to remove them for inspection?
Thanks.
C5 Front Armrest
Jabo
Re: C5 Front Armrest
Mines is being funny as well. If I put my arm rest up then put it down, most of the time it won't catch the lower position and it just goes right down to the floor.
I need to wind it all the way back and try to catch the lower position a good few times until it gets it.
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
mlkey
Anyone? I don't want to break the armrest, but can not see how it detaches.
- x 2943
Remove :
· Armrest (11) (press on the armrest and move it so as to align the lugs “ b “ and the notches “ c “)
mlkey
Thanks Gibbo I will give it another try.
lukkis
Please note that quite a lot force pushing the armrest towards the seat might be needed. The fix for my armrest was just to spray some WD40 and turn the ratchet mechanism with pliers back and forth for a while and adding some more WD40 inside the mechanism.
mlkey
Thanks for the info.lukkis wrote:Please note that quite a lot force pushing the armrest towards the seat might be needed. The fix for my armrest was just to spray some WD40 and turn the ratchet mechanism with pliers back and forth for a while and adding some more WD40 inside the mechanism.
waynedance
- x 8
Does anyone have the pic that's missing on how to remove the arm rest.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
waynedance
- x 8
Sorted managed to remove it.
Wanted to check for damage, I lent over in the the back of the car and pushed the rest back a little. When the rest is in the up position it goes approx 2 inch back more than normal.
Would that be the seat or the arm rest I have broken?
Citroenman80
Mine has been pushed back too far i would imagine by previous owner. it is locked back... is there anyway to remove or realign....?
Citroen C5 2001 2.0 HDI 150,000
C5Alan
Ive got both arm rests are acting up any chance someone still has the pic missing from above????
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
mlkey
I do not have a pic but it is quite easy to remove an armrest. With the arm in its normal stowed position (parallel to the seat back), push it firmly towards the side of the seat. It should move a little. Then while still pushing the arm towards the seat rotate towards the rear of the car for about 90 degrees. As you release the pressure the arm should release from the seat. Fitting is the above in reverse.
C5Alan
cheers will give it a go hopefully see what is wrong and why they are acting up and staying up
C5Alan
Thanks got the passenger side working better and the same with drivers with a good spray of white grease (first thing I found) but a rivet is missing on the drivers side hence its still loose will need to get this sorted as well still not working as well as they should not always catching any hints on getting them to work all the time???
aneesh84
- x 29
did you find a solution. Mine goes all the way down to the handgear, and does not stay horizontal. I opened it completely but could not figure out a hack to fix it.Jabo wrote: 12 Dec 2011, 14:39 Mines is being funny as well. If I put my arm rest up then put it down, most of the time it won't catch the lower position and it just goes right down to the floor.
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
