Xantia heater control slider
froggy
- (Donor 2026)
- x 4
Hi, my Xantia 1.9T.D. The slder switch that controls the fresh air or recycled air , seems to hit against something when trying to slide it to the left. could something have jammed ? anybody got any thoughts Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 8309
Re: Xantia heater control slider
This is a very common problem Terry and it's caused by a kink in the bowden cable that operates the recirculation flap(s) above the blower and air intake. You'll find the kink on the inner of the cable at the slider end.
Sadly, cable replacement is the only completely effective way to fix it although some have succeeded in turning the cable at the slider end so the kink is in the opposite direction.
I say 'sadly' as to replace the cable is a dash and heater box out job and that's a massive one. I personally never use recirculate and leave my cars on fresh all the time. If you're stuck in recirculate and want fresh on a permanent basis, pop the blower motor assembly out (three screws) and push the flap(s) open. You'll see them up in the blower motor aperture.
I say flap(s) as some have one whereas some very late models appear to have two.
I know that's not a perfect solution but I trust it'll help a bit...
froggy
- (Donor 2026)
- x 4
Cheers Jim,
Terry
Chris570
- x 36
I'd be one of them, give it a go, you've nothing to loseCitroJim wrote:This is a very common problem Terry and it's caused by a kink in the bowden cable that operates the recirculation flap(s) above the blower and air intake. You'll find the kink on the inner of the cable at the slider end.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
