sphere changing guide
x 8341
Re: sphere changing guide
Deanxm wrote: Its a mistake many cats only make once
:lol: :lol: :lol:
Saying that though, my two cats are old enough to remember when I had a sinker and they won't go near the underside of any Xantia. They're clever little creatures but not so clever that they the difference between a sinker and an anti-sink.
I did hear, likely an urban legend, of a dog that took shelter under a CX and the poor dog had to flatten itself as the car sank. The owner found the dog spread-eagled under the car next morning but otherwise perfectly OK...
mirafioriman
Unread post by mirafioriman »
Thanks! New one will be ordered on Monday!
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
x 8341
mirafioriman wrote:Thanks! New one will be ordered on Monday!
Excellent :-D The ability of a hydraulic Citroen (and similar vehicles) to be able to give at least two effective brake applications with the engine stopped - and hence a check of the health of the accumulator - will become part of the MOT in the New Year...
Prilliant03
Unread post by Prilliant03 »
I really need to change my accumulator this coming week. Got the parts and the tool, just haven't had the time.
Am I understanding correctly that I need to have the car set on low, supported on stands or ramps, and the engine running when I release the sphere and open the regulator half a turn?
98 Xantia HDi 110
02 Aprilia RST1000 Futura
Life is like a sewer...... You only get out of it what you put in.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I've never bothered with much of that routine. Dump the suspension, with motor still running crack the regulator bleed screw a whole turn past where it "shrieks", then kill the motor. Allow a few minutes sitting, then apply the brake repeatedly a few dozen times. You should be ready after that.
Carsten S
Unread post by Carsten S »
CitroJim wrote: One sphere that cannot be tested without a tester is the so-called anti-sink sphere. It's often overlooked and best replaced as a matter of course.
A good rule of thumb when the anti-sink sphere is dead; The car stays in correct height over the night. At the moment you start the engine the rear-end will sink to low and then raise again.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Carsten S wrote:A good rule of thumb when the anti-sink sphere is dead; The car stays in correct height over the night. At the moment you start the engine the rear-end will sink to low and then raise again.
I wouldn't take that advice literally as S2 Hydractive Xantia's do that as a matter of course with fully charged sphere's,,,,
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Prilliant03
Oh goody. Mine does that so sounds like a new anti sink sphere will be needed too. That's going to have to wait until after christmas.
98 Xantia HDi 110
