Tight Plastic Wing Nut Tip
ecohouse1
x 3
Unread post by ecohouse1 »
I was struggling to release the rear light unit on my Xantia estate because the wing nut had been screwed on by someone who had too much weetabix the morning the fitted it!!
Access with pliers is a pain - ditto moles.
A 19 mm socket fits over it a treat and with an extention bar so you could work out of the boot aperture - it came off in a jiffy
Obviously just hand tighten back on!
Stepto1
Re: Tight Plastic Wing Nut Tip
Unread post by Stepto1 »
Nice one. Struggled with mine before.
By the way, does anyone else use a socket,(forget which size) to wind the brake pistons back in? One of mine grips it nicely.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
ecohouse1
x 3
How does the socket on the Caliper piston work? That sounds interesting.
I used to use a square shafted screwdriver on the BX Calipers and turned and pushed it back.
Stepto1
One in my set just slips on with enough grip on it to wind it back in. The teeth are just the right size.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ah ha someone has sumbled on my secret!!
Yes I DO aswell, I think IIRC its a 21mm socket, and while holding the caliper swung up with one hand, the other on a ratchet is perfect, for those that are slightly loose if you use a long extension then slight downward angle on the socket makes it grip better... It also depends how tight or stiff the piston is to turn back..
Who needs special tools! I bit of thought is all!
Paul
A very sad...
1994 XM 2.1 d auto
Stepto1
Sounds about right. I use a deep reach socket with a short extention. Seems to work better each time! Piston must be getting used to it!
VertVega
x 13
Unread post by VertVega »
Stepto1 wrote:... By the way, does anyone else use a socket,(forget which size) to wind the brake pistons back in? ...
I modified a tool to serve this purpose and added some pics
in this thread :) ---> FOUND the right Caliper rewind Tool for an Xantia
Old-Guy
x 33
Unread post by Old-Guy »
ecohouse1 wrote:A 19 mm socket fits over it a treat and with an extension bar so you could work out of the boot aperture - it came off in a jiffy
Would that be a hexagon socket or a bi-hex or doesn't it make any difference?
