100k Xantia advice please.
Stepto1
Re: 100k Xantia advice please.
Unread post by Stepto1 »
Thanks Rhothgar,I was down GSF last weekend. Ended up with Brembo brakes at the standard price! Discs, pads, two anti roll bar drop links and a tub of copper slip for less then 100 quid. Happy days!
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
VertVega
x 13
Unread post by VertVega »
Estately wrote:It may be worth changing the gearbox oil. ...
I agree with you. Gearbox oil change is often neglected [-X
Mine has passed 200k miles long ago 8-)
Stepto1 wrote:100k Xantia advice please.
Make your camera ready to get a pic when you have the magic numbers on the clock :wink:
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
Stepto1 wrote:Discs, pads, two anti roll bar drop links and a tub of copper slip for less then 100 quid. Happy days!
VERY HAPPY DAYS! I should say. Should last you a while!
I'm going to do brakes all round in mine when I've sourced cheap genuine parts. Did the drop links a few months ago with Lemfoerder ones from Euro Car Parts. They are OEM. Made the world of difference. Ahhhh! Silence!
Rhothgar
(Donor 2026)
x 222
See you have Series 1 Landy. only one I know if in Nottingham and that's Woodborough way.
Got a Series 2 myself. '59, I'm 2nd owner from new and 64k genuine. Originally owned by Caterpillar. It's a pick LWB. Still with original livery. A rare find!
Stepto1
It's up in Mapperley at the mo 'resting'. Needs a new engine really. Hope to have it on the road soon. Brakes seem to be ok now. Still not convinced all is well though in that department. Drop links made things much better. Now a new problem has cropped up. See new posting!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Rhothgar wrote:I'm going to do brakes all round in mine when I've sourced cheap genuine parts.
Brembo are an OE supplier; I bought discs from AutoperformanceOnline (Fleabay) and searched for "Genuine Xantia" pads until something was found.
Northern_Mike
Rhothgar wrote: and have a 900 turbo T16S sitting on my drive. Not a relaxing car to drive!
Heh, no, definitely not. I've had a couple. Standard T16S is bad enough - hilarious fun, but relaxing? No. Lag, wheelspin - in 4th in the wet if you really try. Sweet handling, unless you get boost mid corner.
My second T16 was based on a K-Plate 4 door LPT. 900. Got hold of a T16 that had been rear-ended and transplanted all the bits into the LPT. It then got had big injectors, an uprated FPR and a modified APC box. It got set of uprated dampers and springs, Black diamond discs and pads. It showed 231BHP on the rolling road.. Now, that *was* an interesting beast to drive. It was 4 door saloon, it had a set of Aero alloys, but other than that looked like a standard LPT, down to the badging. It would see off my mate's Boxster though.. :-)
MTND
Unread post by MTND »
Stepto1 wrote:Cheers for that SaabC5. Just thought I might start changing the oil a bit more frequently and change the filter every time. Still fancy an Activa. Or always had a soft spot for a 9000?
Hi Stepto
Mines a diesel I know but just gone over 150k miles and owned now for 11 years. A couple of years ago I went over to changing the oil and filter every 3000 miles and collecting parts where possible. Keeping up with the coolant is a good idea as someone said as with older cars cooling is key :idea:
Hold on to the old ones as they're the best :-D
Mark
1995 Xantia 1.9 TD SX owned 17 years
Alfa Romeo 916 GTV Spider 2005
Ford Focus Titanium X 2017
Rhothgar
(Donor 2026)
x 222
Activa_Mike wrote:
Rhothgar wrote:Standard T16S is bad enough - hilarious fun, but relaxing? No. Lag, wheelspin - in 4th in the wet if you really try. Sweet handling, unless you get boost mid corner.
Your K plate sounds cool.
It never fails to astound me how a standard T16S (Or SPG as it was badged in the US - Special Performance Group) could be so downright quick for only 175/185bhp and then I remember that Saab were the pioneers of bringing the first mast produced Turbco charged car to market and they've never failed to impress since.
Shame they've died as a company. Died in 1994 in all honesty when GM took over.
