Hi all I am new to this site but I have had a Xantia since 1998.
So, Can I purchase a C3 1.4 Diesel six year old with 125k miles, with full service history, I know the cambelt , water pump etc. needs changing at 150k £500 at a Citroen garage.
The Xantia,s I have run have all been OK with high mileage.
Please any advise would be helpful.
xwoody
c3 diesel
Citroenmad
- x 110
Re: c3 diesel
If its a 1.4 8v HDi then they are pretty decent engines, the 16v 1.4 is a little more attention seeking.
If the cambelt has not been changed yet, I would factor that into the costs now and get it replace asap if you do buy it. Ive seen plenty of HDis with failed cambelts before the recommended interval, 125K on a cambelt, pump and tensioners is really more than enough.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
woody298242
Re: c3 diesel
Do I need to look or any other issues.
xwoody
Citroenmad
- x 110
Re: c3 diesel
Injectors perhaps, listen for a rattling from them.
They tend to be a good unit with few problems, so just the usual checks and a good test drive.
I can't think of anything C3 specific, it might be worth a search around on here to find similar posts.
Or check out the honest john webites.
Here is a link to the C3 'whats bad' page, worth a read. While its good to know what to look for, don't let the read put you off, as if you read any review on there you probably wouldn't ever buy another car again
It would appear things are noted even if it has only been known to happen to one car.
Yes, avoid the 1.4 16v HDi
stick to the 1.4 8v 70bhp HDi. £20 or £30 road tax, 60 MPG, low insurance - many plus points. Reliable too.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Deanxm
- x 87
Re: c3 diesel
My work mate has a C3 1.4 HDI 16v, think its a VTR with all the plastic arches etc etc, he had to have the engine out to change the Glow plugs at Citroen
He likes it though.
D
He likes it though.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Citroenmad
- x 110
Re: c3 diesel
XTR is the one with all the plastic exterior bits.Deanxm wrote:My work mate has a C3 1.4 HDI 16v, think its a VTR with all the plastic arches etc etc, he had to have the engine out to change the Glow plugs at Citroën![]()
He likes it though.
D
Wow, bit costly just to replace the glow plugs, is that really necessary?
Still, better than having to take the body off a Dico3 to change the clutch
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Deanxm
- x 87
Re: c3 diesel
Ha ha, i dont know if it was needed or not, ive not seen under the bonnet, i would guess the plugs face forward up upwards but Citroen insisted the engine had to come out, our local dealer is pretty damn good.
Yes Chris XTR, thats the one. Good job someones on the ball!
D
D
XM Prestige PRV6 92
- x 1056
Re: c3 diesel
Not normally but the glowplugs on these engines are known for breaking off in the head which would probably need an engine removal, They are on the rear of the engine & a bit tricky to get at or even see but certainly not an engine out job.Citroenmad wrote:Deanxm wrote: Wow, bit costly just to replace the glow plugs, is that really necessary?
woody298242
Re: c3 diesel
Ok all
Back to the original question do I buy or no
xwoody
xwoody
Sl4yer
Re: c3 diesel
If it's cheap!
We've had no end of problems with ours (electrical / electronic), and sadly I wouldn't recommend one. But many people have no major issues, and there are plenty of early ones still about, so maybe we're just unlucky.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
