Am i right to be wary of....
Ian63
Unread post by Ian63 »
Linked brakes, suspension ect on an 02 C5 2.0 hdi est....it's quite bouncy over the slightest bit of rough rd more than good springs would be. That's one thing, but this carry on with everything being linked is scaring me.......christ even the handbrake's electric!!....or somthing to do with the way it works.
It's seems to a good enough car but this stuff scares me....i prefer proper springs ect...
Dommo
x 20
Re: Am i right to be wary of....
Unread post by Dommo »
The brakes on a C5 are a normal style of brake system with a master cylinder and it's own fluid. Not sure about the power steering but at least you'll have brakes! Or suspension and no brakes should the brake system fail :lol:
x 5672
The estates are a bit harder ride than the hatches but improve considerably when loaded.
As Dommo says, the brakes are not linked in any way to the suspension.
My daughter's Rover 75 is decidedly better than my C5 in town.
The steering and suspension share the LDS reservoir but are otherwise independent with separate pumps for each, the power steering on engine driven and the suspension one electric.
Norlander
Unread post by Norlander »
Our 2002 C5 estate seems to absorb such bumps etc. rather well compared to conventional car suspensions (as did the Xantia before it).
Ian63
It must be the clutch (m/cylinder) then that's linked to the brakes, i still dont like the suspension set up, as the speres (or whatever the hell there called) are not good on bad uk rds
x 2938
Your suspension must need some attention if you think it's no better than an ordinary set up, the Citroen suspension is widely known as a 'magic carpet ride' my 2002 C5 HDI is fine and far better than most conventional cars.
As for the linked system fitted to previous Citroens it was designed to fail progressively if there was a fault, loss of fluid etc, power steering goes off first getting heavy, suspension sinks next and the brakes last so plenty of early warnings.
bxzx16v
x 34
Unread post by bxzx16v »
As above really , the C5 suspension is superb and for ride comfort nothing this side of a C6 comes close
Mark
cachaciero
x 9
Unread post by cachaciero »
The brakes are connected at a system level to the suspension, application of brakes will inhibit any suspension height change (electrical via the brake switch), but this is the only interconnection, sounds to me to be sphere related, the C5 spheres don't have to go very soft before they get spiked and go real hard :-( either that or someone has fitted incorrect spheres, 2.2 Hydractive 3+ spheres would make the front feel hard.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Ian63
There's to many s**t French electrics to go wrong, dont think I'll have it long
XantiaDaveEire
x 4
Unread post by XantiaDaveEire »
Ian63 wrote:There's to many (-expletive removed-) French electrics to go wrong, dont think I'll have it long
Then why'd you buy it in the first place =D>
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
Deanxm
x 87
Unread post by Deanxm »
Didnt know Bosch was french :lol:
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
SaabC5
Unread post by SaabC5 »
My friend has an 03 estate with Hydractive 3 , i have an 02 hatchback with Hydractive 3+ suspension and there is a noticeable difference in ride quality on bumpy roads with the hatchback being far more compliant/comfortable. But load the estate up and there's very little difference in ride quality, i found it similar in the Xantia hatch/estate comparison as well tbh.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
cachaciero
x 9
Take the suspension away and it's no more complicated than any other car on the road all of which generally work the same way and many of which use the same electronics. In my experience the electrics are pretty reliable.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
bxzx16v
x 34
The times I've heard the dodgy electrics on French cars you wouldn't believe , and when people hear the word Citroen they think troublesome hydraulics , well I ran three Xantia 1.9 td's a few years ago as private hire taxis and they NEVER missed a beat , I've also run two C5 Hdi's without any problems . IMO some of the best cars in their class , don't believe the bull**** !!!!!
Mark
addo
Sara Watson's Stalker
x 95
Unread post by addo »
No. You're dead wrong.
But if you want to talk yourself out of a nice car and into something less enjoyable on the road, please go and buy a BMW. They're perfect for the misinformed.
