Apart from the bottom hose one if its been left in a certain position it was a pig of a job to get off on my VSXCitroJim wrote:ecohouse1 wrote: Citrojim - it looks like it has spring clips that you remove with mole grips so maybe that is a relief!
Indeed it isThey're easy....
Can I fit 195/65 R15 Tyres toMy Xantia TD/Radiator
DickieG
- Monaco's youngest playboy
- x 33
Re: Can I fit 195/65 R15 Tyres toMy Xantia TD/Radiator
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8407
True, but a lot, lot less of a pig compared to the bottom hose bayonet RichardDickieG wrote: Apart from the bottom hose one if its been left in a certain position it was a pig of a job to get off in my VSX
DickieG
- x 33
Only silly cars have those hoses JimCitroJim wrote:True, but a lot, lot less of a pig compared to the bottom hose bayonet RichardDickieG wrote: Apart from the bottom hose one if its been left in a certain position it was a pig of a job to get off in my VSX
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8407
You sayin' my Activa's silly?DickieG wrote: Only silly cars have those hoses Jim
DickieG
- x 33
CitroJim wrote:You sayin' my Activa's silly?DickieG wrote: Only silly cars have those hoses Jim
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
- x 188
Go on Jim, test out the forum's warn featureCitroJim wrote:You sayin' my Activa's silly?DickieG wrote: Only silly cars have those hoses Jim
DIY sphere tool
DIY sphere tool
- x 8407
Xac wrote:Go on Jim, test out the forum's warn featureCitroJim wrote:You sayin' my Activa's silly?DickieG wrote: Only silly cars have those hoses Jim
ecohouse1
- x 3
Bayonet Hose Connector?
Just looking at the Rad again on the Xant TD. The two bigger pipes connect into female outlets with what looks like a wire clip?
Is this the dreaded bayonet connectors - whats the SOP for getting the hose off - do I just pull the wire up?
The smaller dia pipe halfway down connects via a spring clip
Cheers
Alan
Cheers
Alan
DickieG
- x 33
Yes that sounds like the bayonet connectors, lift the wire spring clip out of the slot then manipulate the hose out by wiggling it etc.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
